SOURCE: Mother in law has a 2005 Ford Five Hundred
check fuel cut-off switch, shut fuel down on in impact.think its located in trunk, check owners manual. ;hope this helps.
SOURCE: I have a 2005 Ford five hundred and the
You need to have the transmission serviced. The wrench indicates that the fluid in your transmission is out of spec or you have an out of spec pressure condition.
SOURCE: 2005 ford five hundred
If the check engine light stays on when your engine is running, your onboard computer has detected a fault in your emissions system. You need to have it hooked up to a code detector to find out what the problem is. If you are near an Autozone or Advance auto parts store they will usually do that for free. Here is where your search begins. Most of the time the code for "engine lean" will show up. That means you are getting too much air into the intake manifold. Excess air gets in through vacuum tube leaks, intake gasket leaks, faulty EGR, and PVC valves and sometimes valve stem seals, There are also a variety of other codes that may indicate faulty oxygen sensors, catalytic converter, fuel evaporative system. It is too expensive to just start changing parts and hoping you get it the first. It is important to get the codes that are stored in your onboard computer first.
SOURCE: 2005 ford five hundred engine turns over but wont start
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned. To confirm the problem, the basic troubleshooting is required. Click this link below and follow the troubleshooting:------ http://technoanswers.blogspot.in/2012/02/car-starting-issues.html --------- This will help. Thanks
It simply means that its time for routing service and maintenance on your car. This will normally be reset when you take it in for an oil change.
1. Ford has issued a Special Service Message (SSM), stating that the owner's manual procedure is incorrect, and giving a revised procedure. The following is the text of the SSM:
18562 2005 FREESTYLE/FIVE HUNDRED/MONTEGO - OIL LIFE RESET PROCEDURE
THE 2005 FREESTYLE, FIVE HUNDRED, AND MONTEGO VEHICLE OWNER'S GUIDE OIL LIFE RESET PROCEDURE IS INCORRECT. TO RESET OIL LIFE ON VEHICLES WITHOUT MESSAGE CENTER, USE THE TRIP/RESET BUTTON TO TOGGLE THE ODOMETER DISPLAY TO 'OIL LIFE XX%'. THEN PRESS AND HOLD THE BUTTON FOR 10 SECONDS TO RESET TO 100%. THE INSTRUMENT CLUSTER WILL BEEP WHEN THE OIL LIFE IS RESET.
FOR VEHICLES WITH A MESSAGE CENTER, PRESS 'SETUP' TO DISPLAY 'PRESS RESET FOR SYS CHECK'. PRESS AND RELEASE 'RESET' TO START SYSTEM CHECK. WHILE 'OIL LIFE XX%' IS DISPLAYED, PRESS AND HOLD 'RESET' UNTIL 'IF NEW OIL HOLD RESET' IS DISPLAYED, THEN RELEASE. PRESS AND HOLD 'RESET' AGAIN UNTIL 'OIL LIFE SET TO 100%' IS DISPLAYED. THE INSTRUMENT CLUSTER WILL BEEP WHEN THE OIL LIFE IS RESET.
EFFECTIVE DATE: 04/20/2005
