Question about Nikon Speedlight SB-600 TTL Flash
Speedlight SB-600 Display flashing.
Hi all. I have a problem with the LCD display constantly flashing on my SB-600. It has been doing this for months. It seems to work OK, but is annoying. Any Ideas? Thanks Boomer03.
  • 2 more comments
  • Brendan Birmingham Sep 24, 2007
    Thanks Brav.
    We had the random firing thing going on also. We found a crack in the shoe mount that caused the flash to lose contact every now and then. When it regained contact it flashed. Check for a hairline crack in the plastic near where the metal contacts the top of the shoe.
    As for the blinking display, it's still happening, even after numerous services.
    Take care
    boomer
    Thanks Brav.
    Take care
    boomer
  • needafix01 Dec 03, 2008
    I have the same issue with Nikon SB-600. The tech support was not help. If I got it repaired it, the estimate was are around $110. All they do is specify "B2" moderate repair and replacement of parts but could not advise why or how the problem started. Nikon Tech support stinks and very disaapointed with the service received.
  • jokun Mar 19, 2009
    I don't remember how it started, but basically for the life of my speedlight, the display has flashed. Annoyance aside, everything else is fine.
I have the same problem and it was pretty serious. For several weeks I kept the flash unit enclosed in a plastic bag filled with silicagel (desicant) and it seems that it does better, but the problem is not solved for good (2-3 events in several hundred fires).
I think it is a problem with the high voltage chopper (misinsulation or something) and it gets worse in humid environement. This is difficult to prove, but it is the most likely explanation.
The screen started blinking several months ago and never stopped since, but the flash operates normally.
Posted on Sep 26, 2008
I have the same issue with my SB-600, although it does seem to be working properly otherwise. I was in a very reputable camera repair shop yesterday having a D50 serviced when I brought up the blinking issue with the SB-600. They said they've never seen that phenomenon before (although they do all the repairs for Disney, who uses the SB-600 exclusively). The tech said that the blinking display is some kind of "error message" and probably related to an issue on the circuit-board. What puzzled him more was the fact that the unit seemed to be working despite the blinking.
Posted on Jun 30, 2008
I had exactly the same issue, and ended up sending it in for $110 worth of service. The true annoyance is that they would not tell me what the problem was, and yesterday it began again (outside of the repair warranty). It's also firing randomly . . . I'm disappointed to say the least.
Posted on Sep 23, 2007
My SB 600 is doing the exact same thing. I used Nikon's online support service and this is the response I got: "I would try doing the 2 button reset on the flash and then see if that helps. Also disconnect any battery packs you may have connected especially if its a third party battery pack. If none of the above work then please service the speedlight" Sounds like they don't know what it is, either. I tried the reset to no avail. I'm not sure I want to send it in to have it fixed, since it does seem to be working. But you're right, it's annoying.
Posted on May 29, 2007
How I can reset factory set from Nikon Speedlight SB-600?
To reset your Nikon Speedlight SB-600 you need to press Mode + ON/OFF, both buttons simultaneously for approximately 2 seconds to reset all settings, including the custom settings (except the distance unit selected in m/ft) to their default values.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Oct 01, 2010 | Nikon Speedlight SB-600 TTL Flash
Tip
Nikon Speedlight SB-600 won't flash
Hello Friends,
I have SB-600 Speedlight. it dropped from my hand , from then, it goes to READy state but didn't flash.
Please help me to find a solution for repair it or any tech service with resonable rate .
Thanks
Naser
on May 30, 2008 | Nikon Speedlight SB-600 TTL Flash
When put the switche on the lcd display blink contunise
Hold down your "On" button for a few seconds and your flash should reset itself.
Mar 18, 2010 | Nikon Speedlight SB-600 TTL Flash
SB-600 display shows, but will not fire or test fire
there's a part in inside that triggers the light .. it might need to be fixed.
Please contact Nikon Tech Support to walk you through resetting the flash.
a. Have you tried that? it's in the Manual
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-600 Nikon speedlight
You can download a PDF from www.nikonusa.com (www.nikonusa.com/pdf/manuals/Speedlights/SB-600.pdf) and print it out.
Jan 16, 2009 | Nikon Speedlight SB-600 TTL Flash
LCD DISPLAY FLASHING
THE REASON THE LCD IS FLASHING IS THIS . yOU HAVE LOST THE PROGRAMING ON YOUR MAIN CPU . WHEN THE CHIP IS REPROGRAMED THEN IT WILL WORK .
Aug 26, 2008 | Nikon Speedlight SB-600 TTL Flash
SB 600 Not resetting...
my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Flashing LCD
I have same problem too. LCD display continues blinking...
I don't know what to do.
Oct 26, 2006 | Nikon Speedlight SB-600 TTL Flash
Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
bbmw@bellsouth.net
Aug 17, 2006 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
3,009 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
