Question about Regal Ware K813BK La Machine Food Processor
La machine food proccessor lm2 spindle
I have lost the spindle that holds the shreddar up for a lm2 where can i buy one
  • 3 Answers
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
I'm looking for the top lid assembly for the Regalware Lamachine I. Part # A53BC025CL according to Sears, but not available. Looked all over the web but could not find it.
I found several possible replacements on eBay. Look for Regal/Moulinex La Machine II LM2 Work Bowl Cover. Bad news is they're $25 each, used. Ouch!
Apr 21, 2011 | Regal Ware K813BK La Machine Food...
Can I purchacethe cap that goes on after the
Not sure exactly what part you need, but there are some vintage parts for sale here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=la+machine&submit=Search&_sid=93311479
Hope this helps!
Dec 19, 2009 | Moulinex DG6 Food Processor
Need to find a disc adapter for Moulinex La Machine II food processor - Model LM2
345 Passmore Ave
Scarborough, ON
M1V 3N8
Phone: 416.297.4131
Fax: 416.293.9411
Email: info@moulinex.ca
Service: 1.800.418.3325
Dec 05, 2009 | Moulinex DG6 Food Processor
Need replacement food pusher for Moulinex regal ware La Machine II, model LM2
This is For Your Information. The covers for that food processor have been recalled. Click on this link for more info:
http://www.cpsc.gov/CPSCPUB/PREREL/PRHTML89/89069.html
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Regal Ware K813BK La Machine Food...
The center spindle on my Magimix 5150 is stripped and needs to be replaced. Any idea if this is a do-it-yourself project if I can buy the part or should I send it out to be repaired?
Just researching the same problem. Apparently your can find the spare parts here:
http://www.magimix-spares.co.uk/Magimix-5200,-5100-spindle-cover-white,-Nylon-driveshaft-/product/104991/104991/
The old one is has push fit on an inner spindle and apparently can be prized off from outside without dismantling the machine. See the link below for further details.:
http://www.howtomendit.com/answers.php?id=47005
Oct 08, 2009 | Magimix 5150 Food Processor
I need a detachable stem for the slicer,grater discs on the Regal La Machine electronic food processor, Model LM6 375W. TIA, Jo Ann Alexander
Hi... if you have a La Machine I, the item you want is available on nelsonappliance.com for $6.99 + s&h. Search for "disk adapter". I'm not sure about the La Machine II, but the phrase "disk adapter" will probably help you search. Good luck!
Jul 05, 2008 | Regal Ware K813BK La Machine Food...
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Food Processors Logo
610 people viewed this question
Top Regal Ware Food Processors Experts
Henry  Thomas
Henry Thomas
Are you a Regal Ware Food Processor Expert? Answer questions, earn points and help others
