Question about Garden
What is the diameter of the fuel line of a craftsman leaf blower
Craftsman 316.797210 31cc/2cycle/210mphGAS-POWERED VAC-BLOWER
  • 211 Answers
SOURCE: craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Posted on Dec 05, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
  • 430 Answers
SOURCE: 2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
Posted on Nov 30, 2009
Where can I find a Diagram for a craftsman blower/vac carbuerator
Go to searspartsdirect.com and enter the model number and it will give you a diagram for the carb. Hope this helps.
Aug 13, 2014 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
Both lines from carb. are cracked..358.797550 craftsman blower/vac how hard is it to replace the 2 lines and I know one is for fuel, what is the other line for and where does it connect to from the carb. ...
Thin line is the fuel intake and is attached to the fuel filter. The other is the return, and should be placed on the tube below the primer bulb of the carburetor.
Sep 13, 2011 | Craftsman 4 Cycle Blower/Vac
I need fuel lines for craftsman 358.797290 leaf blower
Whenever I cant find the exact stuff I need, try a local motorcycle shop. The fuel lines and such are very similar, often times you will end up with a higher quality fuel line for a few pennies more. Hope it helps!
Jun 22, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower
Hi
regards savumihai71
Nov 09, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
