Question about HP Compaq Presario CQ61410US Notebook
Laptop screen white or light area in bottom corner
The bottom corner of my laptop screen is almost whited out, it changed from the corner on the left to the corner on the right. (It was on the left yesterday, but now its switched?) I thought it might be heat because the left side was next to the exhaust vent, but now i guess it could be a back-light driver issue? I'm running Windows 8, but I don't see how that matters. I have updated my graphics card drivers, changing the brightness doesn't help, and I have tried gently pushing on the screen and frame surrounding it. Compaq Presario CQ61
Try to connect your laptop on an externl mmonitor and see if itd the same.if you have a good resolution on an external monitor your LCD is busted.
Posted on Nov 01, 2012
SOURCE: 2GB SD card no recognized
Thanks.
I have only one card reader. Will see if I can find a way to connect my GPS with the SD card in it to the PC.
Otherwise I guess I need to .. buy a new card.
What do you mean by formatting the SD card. I copy a file on it from Windows explorer (copy/paste) without doing anything to the card? If I buy a new card, should I format it first? How?
Since the system does not recognize the card I cannot do anything to it.
Thanks!
Posted on Mar 13, 2008
SOURCE: drivers for HP Compaq Presario V2000 laptop
pls send compaq notebook presario v2000 audio driver
Posted on Sep 20, 2008
SOURCE: I need audio drivers for compaq Presario F500 laptop
 helo ser i'm joni rahman . from indonesia  plis whit deriver vga,sound,wireles, driver to all fromPresario 500 laptop
oke thengs ser
Posted on Nov 17, 2008
hmerchant110
  • 7191 Answers
SOURCE: I need driver webcam for HP Compaq Presario CQ61-115TU
You can download the required drivers from: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=ca&lang=en&product=3938467
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Aug 24, 2009
White patch on corner of my laptop
Has it been damaged? Bumped? Dropped? on that corner?
Jan 20, 2013 | Samsung R730 Notebook
So I'm turning on my inspiron 5100 and all i get is a white screen. It sounds like it's on but the screen remains blank white?
Hi Donny,
A white screen usually means the LCD panel has failed/worn out. Here's an easy way to make sure. Get your laptop to an external monitor, whether at your home or a friend's place, and with the laptop off and the external monitor off, connect the monitor video (vga) cable to your laptop. Turn them both on and then on your Dell laptop hold down the fn key down in the bottom left hand corner of the keyboard and press the F8 key up at the top. That transfers the video signal to the external monitor.
If the external monitor shows your laptops normal desktop and icons, then you know for sure the LCD screen on your laptop is worn out. If you get the same white screen on the external monitor, it means the video card/controller on the motherboard of your laptop has worn out and you can move ahead with deciding on repairs or other options.
Good Luck.
PS....if the F8 key doesn't transfer the video signal. look at all the F keys for one that says CRT or one that has a little picture of a monitor to transfer the signal.
Sep 01, 2010 | Dell Inspiron 5100 Notebook
My Sony laptop colors changed. The white area of
may be the problem with your vedio card setting or vedio card and sometimes it happend with your display screen also.
Jul 14, 2010 | Sony VAIO Notebook
I think there is a loose wire from the laptop hinges to the screen backlight when i open the laptop it only lights at a certain position and have to move the screen back and forth to get the light on
dodgy conection to the screen inverter take off the screen surround 4 poss 6 screws located in each corner of screen and poss 1 behind each hinge in the middle at bottom of screen make sure the pink and white wires are connected properly if not press them in if they are the problem is 1 of 2 things either the inverter is faulty or the pink and white wires are either snapped or not connected to the back of screen or motherboard correctly
Oct 09, 2009 | Computers & Internet
There is a light area in corner of may laptop lcd
Is it a light or a Pixel
If its a white dot it is a pixel in your screen and not a light, you lcd has a bad spot in it..
Aug 10, 2009 | Dell Computers & Internet
Hello I've got this problem. when my computer running, sometimes my screen go white screen and i can't see at all to the windows, just white screen. but all function is ok so i press power button to...
got this from a friend: Apparently some series of Acer notebook came with BAD_EDID laptop display. The only thing wrong is the checksum which is 9D and should be 1D. Powerstrip 3.76 (registered version) managed automatically to correct EDID.
There is no problem with drivers from 101.x series, but with any newer driver max. resolution is 1024x768 and the picture is in left upper corner of the screen with black bar on the right and smudged taskbar to the bottom of the screen. After installing and restarting resolution is set to 800x600 what results in white screen whit thick black bar slowly appearing on the screen.
Jan 27, 2009 | Acer Aspire 3690-2196 Notebook
My tablet only recognizes a fraction of my screen
Hey!
I had the same problem with my bamboo one.I just had to re-install the driver (from wacom-europe.com) and now it works perfectly. I suggest you try to do the same. :)
Jan 07, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Bottom 8mm of laptop screen is not showing but can be clicked and used. has turned grey and stripey with a white patch in the left corner
Its a problem with the display. Check the screen resolution. Also uninstall and reinstall the display drivers.
Thanks.
Oct 14, 2008 | Computers & Internet
HP Compaq Presario CQ61410US Notebook Logo
599 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
