Question about HEWLETT-PACKARD Computers & Internet
My lincoln ls 2005 shakes while idle also it feels like it wants to shut off while driving
  • 2,878 Answers
Try Super for a while.
Posted on Nov 01, 2012
Why does my fan run at high speeds for my 2005 ls lincoln
If you mean the radiator fan, the switch in the engine block that tells the drive train engine module when to shut down is probably bad. This switch/sensor probably needs to be replaced. It is located near the water pump and thermostat.
Dec 29, 2014 | 2005 Lincoln LS V8
Lincoln ls shakes
Is you "check engine" light on ? If it is you can take it to most of your local auto parts store and have them pull diagnostic trouble codes (DTC's) for free which may help narrow down the cause of it shaking. Not sure exactly what you are saying. Do you seem to have hesitation when pressing down on the gas to move ? As you are driving is there or does there seem to be a "stutter" once in a while like a chug. I say this because Ford products (your engine V6 or V8) have a separate coil for each spark plug that basically sits on top of the engine. Since your vehicle is a little older the coils go out on them because of the heat which causes a misfire which would cause shaking like you described. A misfire code would be in the P0300's area on the list of DTC's. I may be way off base but this is a common thing that happens with this coil on plug system. Hope this information helps....
Oct 31, 2012 | Lincoln Cars & Trucks
2005 lincoln ls has 1500rpm idle when started would like to adjust it down
The idle is controlled by the PCM, there
is nothing to adjust,it is all drive by wire
Does it go down to 750 rpm after about one minute
from a cold start ? About 1200 cold-- that is normal
Are you in a hurry-- let the car warn up, it won't run on
O2 Sensors for about 5 min until warm
Make sure your using 5W-20 full syn oil every 4,000
miles at most & change the power steering fluid & trans
on all veh every 3 years-- if you want them to last
I have a 2004 LS V8
Do you have stored codes ?
Have you had other issues lately ?
Is the battery original if so replace it,
that is your problem
Have to get battery from dealers parts counter
as it has a vent for the hose out of trunk
The price is on the web site & is not discounted to
repair shops
I think I paid $119.00 in May but i pay no tax
Oct 20, 2012 | 2005 Lincoln LS
2005 lincoln ls shakes when idling
Run a leak down test on it.You may have a burnt exhuast valve.
Jan 14, 2012 | Lincoln LS Cars & Trucks
When driving my lincoln, it has a slight shake. Do you know what that could be
Most likely a tire that has a broken bet,or there is a front end part that is bad.
Aug 24, 2010 | 2000 Lincoln LS
03 Lincoln LS Check engine light on and car is hesitating
Just figure i would try and help, Did you get gas just before this happened? It could be as simple as bad gas, However i have seen problems with them having bad ignition coils.
I think its like $300 for a diagnostics at a Lincoln dealer and i know you can get a set of six ignition coils for $225.00
Well good luck in the morning and i hope it is just bad gas, Well let me know and good luck.
Jun 24, 2010 | 2003 Lincoln LS
Rough idleing shaking within engine engine light on
could be automatic choke killing revs > could be one bad plug mis fireing on idle. car tune up required. hope this helps?
Aug 27, 2009 | 2001 Lincoln LS
2002 lincoln ls idling shaking when put in drive.
Hey i just had this same sounding symptoms with my 2000 ls. It turns out that the ignition coils were failing (2,6,8). Just replace all of them. All of them i got on eBay for 150 bucks when the garage quoted me 1100 bucks. Good luck man.
Apr 09, 2009 | 2002 Lincoln LS
2000 Lincoln LS--Check engine light blinking/sputtering take off
you need to find out what codes have been set
one of your coil packs is going bad.
the code should tell you which one
let us know how you do
later
paul
Nov 19, 2008 | 2000 Lincoln LS
Computers & Internet Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
