Question about Sanyo DS25390 TV
Only getting some channels to come in...
I can only get channels 2 thru 13 on my tv. The rest of the channels 14 thru 51 wont come on. They are nothing but static. I have gotten them on before. When I auto program it only adds 2-13. Do I need to manually program them and how do I do it?
  • angitidwell Jan 04, 2009
    thanks but thats not the problem. i have all of my regular channels in all of my other rooms. :o)
  • 45 Answers
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Posted on Jan 04, 2009
  • Nick Arrain
    Nick Arrain Jan 05, 2009
    If you go through the menu, After auto prorgram their should be a manul program option. Try using that.
Ilost some of the channels on my panasonic tv vhs combo how can reset it my model # PV-M1323 THANK YOU
What you have is a bad tuner in the set---2-6 is low vhf band-7-13 is the next band--14 and above is the next band of channels---clearly your 7-13 band is bad.
The tuner may be able to be removed and the board inside it resoldered---a replacement tuner even if available would cost more than a new unit.
Dec 06, 2012 | Televison & Video
My RCA E13344 Tv is connected directly to the cable wire (no cable box) on the menu i set the tv to cable tv and serch for the channels. After the serching is done the tv stops at channel 7 instead of...
I'm sorry for the difficulties you're experiencing in getting the few channels. I suggest that you unplug the TV to perform a power resetting and then perform auto programming to resolve the issue. Please let me know if the issue persists.
Dec 29, 2011 | RCA E13344 13" TV
I hooked up my proscan to comcast cable, i can just get first 13 channels.i tried going into settings and doing channel search, it will only clickon analog, not digital channels what can i do to get the...
Cocast may have only transmitting NTSC Ch 2~13 only for your area, to get more channel you may have to use Comcast cable box, I am in bay area, I can get 2~35 for basic plus service, I can get 2~13 for the most simple service for less money. What is your serivce level you are paying for?
Your TV also anly has NTSC tuner, there is no QAM or ATSC turner.
TV SPEC; http://reviews.cnet.com/flat-panel-tvs/proscan-26lb30qd/4507-6482_7-33403393.html
You may have to call Comcast.
Mar 09, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
I get channel until #13 how does i get the other chnnel
TV's of this era have two modes that the tuner can work in. One is the AIR mode and the other is CABLE. In the air mode the tuner picks up only "off air" frequencies,... and up to channel 13 they happen to be the same as cable channels 2 thru 13. If you are using cable you will need to go into your on screen menu and find where to change the tuner from "air" to "cable" to get channels above 13. Older sets had a switch on the front and sometimes the back to select the tuner mode.
Aug 14, 2010 | Curtis CM19033S 19" TV
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
GE TV/VCR 1995
Have you tried retuning for ch 10? Is your TV on the same antenna/ connection as the rest in the house?
Mar 26, 2008 | GE 13R100T 13" TV
Tv remote
My Comcast pkg should enable me to get chanals 2 thru 243, but my Orion TV only lets me get up to 72. How can I enable the TV to get the rest of the chanals?
Feb 04, 2008 | Televison & Video
13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Oct 12, 2007 | Sansui COM312AD 13" TV/VCR Combo
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
289 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
