Question about Microsoft Xbox 360 Controller
We have 2 xbox 360 controllers. The one works fine and we use it all the time. We recently got our first 2-player game. We went to turn on the second controller but it won't turn on. It has brand new batteries in it and it's not the battery pack. We tried it in the controller that works. When we try to turn it on, all four lights around the power button just continuously flash.
You have to first sync it with your xbox... there should a little white button on top of your controller, and a white button next to the memory card slots of your xbox.. hold both for 3 seconds to sync them
Posted on Jan 05, 2009
Game Mat as second player? how do I make it the first player
Turn off both controllers, then start the one you want to use as first, first. If that still fails, you can turn off both controllers then resync the first one using the sync button on the top of the controller and front panel of the xbox. If you are using a wired controller, you will most likely need to turn your xbox off then on, and connect the controller you want to use as first player, first.
Nov 15, 2013 | Konami Dance dance revolution bundle xbox...
My controller was working one day and then stop working the next day it had fresh battery
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Jul 31, 2013 | Microsoft Xbox 360 Controller
Wireless Xbox 360 controller turns on, connects, then turns off after it chooses a player number.
It sounds like your new controller needs to be "sync'ed" (synchronized) to your console so that the console recognizes the controller. Turn on console with controller. Then press sync button on front of controller (small button) and then within 20 seconds press little sync button on front of controller (not the top, its the forward part facing console, little button)
Oct 09, 2017 | Microsoft Xbox 360 Controller
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to http://rockbandservice.ea.com to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
Xbox wirless receiver not working!!!
Probably defective. Get you a new one.
Jul 26, 2009 | Microsoft Xbox 360 Controller
My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
May 30, 2009 | Microsoft Xbox 360 Controller
Screen won't show up but this is diffrent
This happened to mine and it had to be sent back to be repaired (3rd time) as the graphics card had failed; it started with the display colours looking strange, then the picture went totally. If you can hear everything working (beeping/whooshing" as you go through the "blades", it sounds like you have the same problem. below is how to reset to the default display sttings just in case anything has gone wrong on this.
To reset the display settings of the Xbox 360 console to the default settings, follow these steps: (Copy and pasted from Microsoft support pages)
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Turn the console on.
    Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
If this doesn't work then try phoning XBOX Support on 0800 587 1102.
Dec 23, 2008 | Microsoft Xbox 360 Console
Video output on wrong setting and cant see screen
for PS3, hold the power button for at least 5 seconds or until you hear a second beep.
for Xbox 360,
Sep 05, 2008 | Video Game Consoles & Games
XBOX 360 CONTROLER PROBLEM
Go to settings and turn controller invert off. (y axis)
Feb 24, 2008 | Microsoft Xbox 360 Controller
Wireless controller
to activate the second wirless controler you have to press the search button on the xbx360 just below memory unit b, then press the search button on the controler aswell.
Dec 30, 2006 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
