Question about Western Digital Computers & Internet
I have an external Western digital hard drive that is faulty. when i plug it to my system, it will not appear at the task bar. But when you go to disk management, u will see Disk 1 unknown, not initialized. when u right click and click initialize you will get the following answer; Incorrect function. Plz help me out if u have the solution. thanx
  • Ikechukwu Isaac Nov 01, 2012
    Thank you all for all your contributions. But it hasn't worked yet when i try to change the path letter but all to no avail. it's still saying; incorrect function.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 457 Answers
Do you have a friend who has a computer you can try it on?
Posted on Oct 31, 2012
3 Suggested Answers
  • 77 Answers
SOURCE: I have a WD 1TB Hard Drive. The HD shows up in
Try the following steps:
1. right click on my computer and select manage
2. choose Storage-> disk management.
If you say that the drive appears in the "safely remove hardware" than it should appear here too.
Select the hard drive and select "change drive letter and path". Add a drive letter and your hard drive
should appear in my computer.
Posted on Feb 11, 2011
  • 160 Answers
SOURCE: The Samsung Freeagent GoFlex external
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
Posted on May 03, 2011
External hard disk WD 500gb icon absent in my computer window?
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked. Get it from http://www.any-data-recovery.com
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.
Mar 29, 2012 | Western Digital WD Elements Portable...
Tip
Same problem here.........clicks n all...... After smacking the external hard...
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the experiences is the same as a DEAD Hardisk. Anyways, as I read that sometimes this happens as a result of a hit, well, I wacked my HD as a last hope for it to recover its "memory" (as in the movies) and believe me or not, it worked! I don't know if this might help yours, but it saved mine!
The way I did it was like this: I started the pc and when the HD started to run and I heard a couple of clicks, I hit it against the table while in vertical position (assuming that the arm of the HD might slightly move better that way) one time, and then when the spinning and the first click was heard agin I hit again. After that I heard the typical searching sound of a HD, and you can imagine I started to pray that what I heard wasn't my anxiety sound (if it has any). Now I am a firm believer in the old trick of whacking the old TV to get the vital signal back!
Good luck to you too!
on May 29, 2009 | Western Digital 250GB MyBook External USB...
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
I have a Western Digital 500Gb External Hard Drive. when ever i plug it in, i am unable to open any applications on my PC such as Internet Browser, douments Etc.. i am also unable to access my hard drive...
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
4. the drive may not be supported by the motherboard for your PC.
5. Scan the drive with Microsoft Security Essentials" found at Microsoft.com Download ( its free). You may have a virus.
Mar 17, 2011 | Western Digital My Passport Essential...
When connecting my WD 1tb external Hard Disc my task bar freezes why?
WHY NOT TRY TO CONNECT WITH PC "SHUTDOWN", SEE IF PROBLEM GOES AWAY..........HOPE THIS HELPS...........JEFFXC
Feb 23, 2011 | Western Digital MY BOOK HOME 1TB EXT...
External HDD not detected
have you try with the other usb cable and the usb port.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
External hard disk not detected in explorer
Try a different USB port and verify the cable is good.
Now that i have plugged everything in on my western digital my book external hard drive 500gb what do i do next
Once you have it connected to your pc, the pc should have an icon in the task bar by the clock saying installing device, once it has finished it will say device installed & is ready for use. You will then see a new hdd under the my computer icon. You can then use your drive as you wish. Hope this helps.
Sep 19, 2009 | Western Digital My Book Essential Edition...
Computers & Internet Logo
213 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
