I have an Ibico EL-12 II laminating machine. The front of the machine will not feed the doc in.   I tried to use the back of the machine to see if you feed the sheets in that way and the rollers are working b/c its actually the side the docs come out?  Can you assist?
SOURCE: I have a Ibico el12 ii laminator and need to know
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Posted on Oct 02, 2009
  • 72 Answers
SOURCE: doc 12 and vista
no.
Posted on Sep 04, 2010
SOURCE: My office has an Ibico
I need a new cord. Also, the machine does not get hot enough to melt the holes.
Posted on Jun 22, 2011
SOURCE: bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
Posted on May 31, 2012
SOURCE: auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Posted on Jul 30, 2012
User manual for ibico pl-330 ic
http://office.manualsonline.com/support/other/laminator/laminator-manual-required-2292677
Oct 12, 2014 | Office Equipment & Supplies
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
I have a Ibico el12 ii laminator and need to know how to use it. I cant find the instruction manual for it at my new job i put the sheets in as it shows but it labinates the first 1/2 inch then goes no...
Jul 02, 2009 | Office Equipment & Supplies
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Mar 21, 2008 | Ibico 1202 Calculator
382 people viewed this question
jasbo
jasbo
