Question about Edirol UA-25 External Sound System
Crackling noise - help
Hi, I just purchased this gear and I'm having a hard time with the playback. I'm using the Sonar LE that came with this and the the playback is always crackling. My comp 16-bit and 44100 sampling rate... What am I doing wrong??? Please HELP ME Email me at girl.inspired@yahoo.ca Thank you!!
  • 1 more comment
  • novio7 Nov 18, 2007
    Hi
    I have exactly the same problem. The gear is absolutely brand new and the cords are all connected properly. Could it be a Windows compatibility issue? I am open to any suggestions.
    Thanks.
  • stacey kavanagh Jul 06, 2008
    I am also experiencing the exact problem, adjusted latency, buffer... what is the problem? Anyone any ideas or resolved this???
    I have the exact same problem, have adjusted latency and buffer levels, Im so confused, I have this product 3 weeks now and cannot record without getting pops and clicks!! Help!! Has anyone since resolved this issue?
I had this problem recently and I fixed it by correcting the latency buffer size (found under options - audio... - in sonar 7) - move the slider to the left (fast) side of the scale. Hope this helps.
Posted on Jan 03, 2009
    Sergeant:
  • 457 Answers
Check all your cords make sure they are connected proper if they are then its internal. Is the gear brand new if so its under warranty if not then come back and ask again. It takes a brave person to answer your direct email address that means you are able to see who the person is ie his email address you will know. On fixya people dont like emailing others because the others maybe spammers....hence the Report abuse button on this program!
Posted on Sep 10, 2007
I own a Sony Camcorder SR-DCR210E with hard disk. Lately, I noted that on playback I hear loud crackling noises each time I change scenes, presumably each time I switch the camera on or off. What...
The loud " Crackling noise is you hands , moving from one place to another on the cam ! " I too have this problem with my cam..It is Inherent,its the powerful mike they have.
Apr 15, 2011 | Sony Video Cameras
I have sonar 6 le on windows 7. I am using a cakewalk roland interface. something is wrong with the sound, it makes noise during playback. I also hooked a mxl v67 mic and it is sounding pretty wired dont...
I suggest you make a backup of your music files, uninstall cakewalk and reboot your computer to make certain there are no files left in the RAM then re-nstall it. That will ensure that your installation is a clean one.
If that has no effect, remove the sound drivers from your system and re-install the latest versions from either Windows or the manufacturer's web site.
That should fix your problem.
Hope this helps.
Oct 28, 2010 | Computers & Internet
Cakewalk Sonar - Edirol UA-1000 crackles on playback!
That's a latency issue it sounds like.
There's a slider under "Audio" .
Move it in increments towards "slow", test it as you go.
Leave it at the highest setting possible that doesn't crackle.
I've heard this so bad that it sounds like a gun going off.
It scares the Hell out of you when it happens !
Jan 20, 2009 | Edirol UA-1000 External Sound System
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
PLaying and Recording
Look in your MIDI instruments and make sure the icon for you to play back is lit.
Apr 20, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Crackling when recording with saffire
Without much info to go on I would first make sure that your input levels are not set too high when recording causing clipping and digital distortion on playback. Usually this is the thing that causes crackling sounds. Rather hard to fix after the fact and you may have to rerecord those tracks to get a cleaner sound you are happy with.
Jan 03, 2008 | Focusrite Saffire LE FireWire Audio...
SONAR LE NO AUDIO
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Sep 04, 2007 | Edirol UA-25 External Sound System
Problem with playback
Hi, I have the same audio interface. Alright, make sure that all of your effects are turned off. you probably (and most likely) have the "fx voice", "amp drive", "chorus" and "delay" effects turned on (bottom row). There is no way you should have distortion with tremolo & reverb on playback all the same time without the effects being turned on. the pop ticking could be produced by the buffer size. If youre using Sonar LE, you should tweek the buffer size until playback sounds smooth. I hope I helped! Good luck!
Aug 14, 2007 | Edirol UA-4FX External Sound System
Timing and noise
That's usually caused by problems with the usb port on your computer. The best solution would be to buy an PCI USB CARD that you would use only for your UAFX4.
Aug 09, 2006 | Edirol UA-4FX External Sound System
Edirol UA-25 External Sound System Logo
845 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
