Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
  • margiebarlow
    margiebarlow Nov 01, 2012
    I have the same problem
    Top Expert:
  • Maytag Master
  • 9,472 Answers
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Posted on Nov 01, 2012
  • 1 more comment
  • margiebarlow
    margiebarlow Nov 03, 2012
    Already tested that part.
  • margiebarlow
    Fact is, it is cheaper to get another dryer from craigslist than to buy the timer
  • Richard Roth
    Richard Roth Nov 03, 2012
    You are absolutely correct.
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Hi i need the part number for a maytag atlantis dryer timer
part number for timer is AP4043083 , if you also need the timer clutch that number is AP4042974 both thru appliancepartspros for about $85.00 each
Mar 05, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
I have a ldg382 gas dryer. The dryer runs and heats a little, and the timer will not advance, stays in same position.
disconnect vent tube, run dryer as it shall work now. I would guess restricted vent tube. Good Luck Tim
Jan 16, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
What is the part number for the timer?
The timer for Maytag Atlantis MDE6400AY is part number 33002855. Specify the model number of the dryer if it is different from the given above.
Apr 26, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis Electric Dryer
Fly, sounds like you blew the thermal fuse. This is located on the front blower. You will need to remove door by removing the two screws and lifting up on the hinge. Remove the 2 spacers on the other side of the door. Now the panel will pull out and the blower will be exposed. The fuse will look like the one on the right of the attached picture....Catriver..post back.
Jan 26, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
201 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
