Question about EliteGroup Computers & Internet
Short circuit in hdd model HD161GJ - EliteGroup Computers & Internet
  • 3,799 Answers
Unless you are an Electronic Engineer you need to replace the HDD
Posted on Nov 03, 2012
Error 602.00003
A data read fault of the HDD is detected when the HDD is started up from the BOOT ROM Causes The wiring is faulty (short circuit, open circuit). The HDD is faulty. The main controller PCB is faulty. Remedy 1. Wiring Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal? NO: Correct the connector/cable. 2. System software Try re-installing the system software. Is the problem corrected? YES: End. 3. HDD, Main controller PCB Try replacing the HDD, and download the system software. Is the problem corrected? YES: End. NO: Replace the main controller PCB.
Dec 03, 2014 | Canon Office Equipment & Supplies
Dear Sir, My HDD Details : - Model : HD161GJ HDD P/N : HD161GJ LBA 312,581,808 160.0GB S/N : S14DJ90Z446270 P/N : 61763-A71A-A63JX my problem is on this HDD any OS installed, this OS In...
You may have a bad sector where the OS resides on the drive. Download what is called a low-level formatter. This software is designed to lay down the actual tracks where data is stored. It is different that formatting with the OS. This will put the drive back to the original unformatted condition. After you do the low-level format, you will need to format the drive again with whatever version of OS you use.
Apr 16, 2017 | Computers & Internet
Sp1203N HDD when I plug in the power cable to the HDD it shuts down the PC power supply and there is a electrical smell from the HDD unit
That's a strong sign that the electronic circuit-board under the disk-drive has short-circuited, and has melted-down.
It's time to purchase a new disk-drive.
Oct 30, 2010 | Samsung (SP1203N) 120 GB Hard Drive
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
Dear sir i have ir3300 cannon yesterday i switch on the machine monitor showing E602-019 HOW TO SOLVE THE PROBLEM
E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0003 A sector fault is detected on the HDD.
0004 A fault is detected in the read /write address for the HDD.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
BUT FIRST: TURN OFF THE COPIER SIMOULTANIOUSLY PRESS 1 AND 9, HOLD IT, AND TURN ON THE COPIER. THIS WILL INITIALIZE THE HDD DEFRAG MODE.
TRY IT, IF NOT REPLACE HDD, AND UPGRADE SOFTWARE - NOTE: FOR UPGRADE YOU NEED THE SERVICE SUPPORT TOOL - CALL SERVICE FOR THATH
Feb 13, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have installed a hdd to an hp pavillion zd7000 with no hdd cage,problem is it wont turn on but if i remove hdd it turns on,what seems to be the problem?
The only thing that comes to me is that the naked disk short circuits something. Or, possibly, the disk is installed incorrectly and prevents the system from booting. Check the connector is properly oriented and aligned. Last possibility, the hard disk is defective (e.g., it has a short-circuited power section).
Oct 28, 2009 | Computers & Internet
Canon Image Runner 2200, receiving error message 602-0003
It's related to copier HDD try with some technician to replace HDD or reinstall HDD software.
A data read fault of the HDD is detected when the HDD is started up. or
also check -
Jun 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Computers & Internet Logo
55 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
