Question about Apple iPod touch
Ipod stuck on with white screen
It is turned on and wont turn off . The screen stays white.
I purchased music and now i need to get it on to my mp4
Posted on Jan 04, 2009
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
--please help. i pod 4gb silver has white screen. does not turn off i hear 2 beeps. it stays on with white screen. What do I do?
Hi leahschecter
***White Screen of Death***
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Bud
Nov 25, 2012 | Apple iPod MP3 Player
My ipod screen just stays White. My daughter can play Music on the chargeable station. But i turned it off and on and it goes to Clear White Screen everytime.
Try to reset the ipod:
- iPod Classic: Press Menu & Center button at the same time for at least ten seconds
- iPod Touch: Press Center button & top button at the same time for at least ten seconds
Apple logo will appear, and the iPod will be reset (you won't loose your music)
Oct 08, 2009 | Apple iPod touch
My iPod touch is frozen at a white screen, i tried restarting it but it just makes the camera snap sound and thats it. HELP PLEASE!
well if your ipod wont turn on at all, its probably your home button that is stuck. If your home button isnt stuck, connect it to the computer and then restore it.
Aug 14, 2009 | Apple iPod touch
Screen on iPod Nano went blank (white)
press the play and pause button then on the bottom of the ipod theres a orange swich and make it turn orange...
Jan 27, 2009 | Apple iPod nano
White screen on nano ipod
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Aug 11, 2008 | Apple iPod nano
My ipod nano wont do anything
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Aug 05, 2008 | Apple iPod nano
IPOD NANO - Starts With White Screen, Stays With White Screen. Can't see Anything.
1 Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
2 Press and hold the Center and Menu buttons for at least 6 seconds, until the
Apple logo appears. this resets the ipod
Mar 16, 2008 | Apple iPod nano
Ipod nano
http://www.zolved.com/synapse/view_content/19067/The_Apple_iPods_White_Screen_of_Death
Jan 18, 2008 | Apple iPod nano
Ipod white screen
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Apr 13, 2007 | Apple iPod nano
Apple iPod touch Logo
91 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
