LAN ATHEROS PCIE ETHERNET CONTROLLER v2.02.7(11/02/10)
map9966
  • 2351 Answers
SOURCE: Lan adapter
Juda2008, please tell me how this came about? Where you installing windows? (Fresh install)? Did the NVIDIA LAN driver function before? Or did you just loose the ability to connect to the internet one day & tried to re-install the driver. Than windows reported there is no hardware for this controller? If this is the case, double check in you're bios, page 32. Make sure you're onboard LAN is set to, Enabled. If it is set to Enabled & you are unable to install the correct driver software for the LAN controller, than the onboard controller may be defective. If this board is still under warranty through PC Chips, suggest you call tech support for an RMA. If you're board is not longer under warranty than buy a PCI LAN network 10/100 card. http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=402915&Sku=N100-1420%20P&SRCCODE=CNETFEED&CMP=OTC-CNETFEED
There is one other way to try to install the controller for you're board. Go to PC Chips web site & download the NIC driver software. Create a folder on you're desktop & name it. Click on this link, download the NVIDIA Ethernet Driver into you're folder. http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=392&DetailName=Driver&MenuID=7&LanID=2
The driver file name, Nividia_33nm.zip must be uncompressed. Do this within the folder on you're desktop. Now open device manager. Find the yellow ! point for the missing driver. Right click once on the ! point & slide up to & left click update driver. Windows hardware wizard will open. Click No, not at this time & than click the next button. In the next window, click Install from a list or specific location (Advanced), than click the next button.
In the next window, click on the green check mark next to; Search removable media (floppy, CD-ROM...).
This will remove the green check mark. Than click the Browse button. Go to you're desktop & open the folder you created.
Click on the folder NVIDIA so it is highlighted, than click OK.
Windows should install the NVIDIA Ethernet Driver software.
If you receive the same error message from windows than you're NIC controller is defective.
Mike
Posted on May 31, 2008
colliewob
  • 778 Answers
SOURCE: Ethernet controller problem
go to device drivers and update the Ethernet drivers
Posted on Aug 07, 2008
CosmaP
  • 409 Answers
SOURCE: atheros int. controller incompatible with windows7
Use the appropriate vista driver, if it exists.  or get a usb to rj45 adaptor
Posted on May 20, 2009
map9966
  • 2351 Answers
SOURCE: audio&video controller,atheros ethernet driver
Click on the link below provided by Mercury and download the drivers you need;
http://www.mercury-pc.com/product-drivers.php?productid=644
Enjoy!
Mike
Posted on Jun 19, 2010
NavyBlueWiz
  • 77 Answers
SOURCE: im heving a proplem with
Hi there! You can actually download the drivers on Dell's website. You can either use the model number or use the Service Tag on your Optiplex Computer to show all the drivers for your computer.
I was able to browse to their site, and was able to list down all the drivers for your computer. Click here to get into their website.
You would still need to select the appropriate Operating System for your computer to download the compatible driver for your ethernet controller.
Hope this helps!
Posted on Apr 07, 2011
Need Acer 5253 Ethernet controller driver
here. but first choise the operating system. and after lan driver
http://support.acer.com/product/default.aspx?modelId=3473
Dec 06, 2012 | Acer Atheros AR8121/AR8113 PCI-E Ethernet...
No bootable device packard bell-what do i do?
check your bios settings and make sure your hard drive is first in the boot order.
Nov 24, 2012 | Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Lan and wireless driver for toshiba a135-s2246
Unfortunately, the Toshiba Satelite A135-S2246 was never designed to run XP, only Vista. Which is why you can't find any drivers for XP. The nearest you can get is to find a laptop running XP SP2 that is using the same LAN (ethernet controller) and WLAN (wireless ethernet controller), and see if they will work.
Here are the drivers I found for XP (please check which one's you are trying to install):
Atheros WiFi card driver:
http://www.wireless-driver.com/download/atheros/2007-7-23/Atheros-ar5bxb6-AR5424-mini-PCI-E-Wireless-Card-Driver-Download.htm
Intel WiFi card driver:
http://downloadcenter.intel.com/default.aspx
You will need to search for the card that you have.
LAN (ethernet controller):
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
You can pick third or fourth from top depending on your preference.
Please remember that Toshiba, Microsoft, Atheros, Realtek, Intel and especially myself accept no responsibilty for what may, or may not happen when installing drivers not specifically designed for your system. All that said, I hope it works for you.
Dec 05, 2008 | Toshiba Satellite A135-S2246 Notebook
Computers & Internet Logo
David Payne
David Payne
