Question about Compaq Evo Notebook N150 Notebook
Fix for 0232
Has error code 0232 extended ram faild at off set have to hit f1 to boot or f10 computer set up done both no luck do get blue screen if f1 after 15 mins or so
    Scholar:
  • 106 Answers
It is a RAM error, it means that you system has a falsified RAM. To ensure that this is a problem, simply take out your RAM and plug in another one and see if it resolves the issue. Lend a RAM from your friend for sometime before making a new purchase.
On laptops RAM is located on the Back side and has quite easy access to it. You can generally open the RAM cover by simply opening two or four screws.
Also, this has sometimes works out for me, that I plug a RAM out and then start my computer. Obviously you shall hear a beep and nothing shall be shown. After about 10 to 15 Seconds shut off the laptop and again plug the old RAM and see if it works.
Posted on Nov 01, 2012
Paeroa
  • 457 Answers
SOURCE: BIOS Clock Error
Update the BIOS or CMOS it should be fine after that.
Posted on Sep 09, 2007
SOURCE: System board comm fault
Conda, what are the steps one generally takes to resolve an IRC conflict? Where is the UI? Is setting in the OS or BIOS or both?
Posted on Aug 15, 2008
SOURCE: No responce from keyboard
The keyboard is not dead. I have contacted HP about this issue (DO NOT CALL THEM AND HAVE THEM FIX IT! THEY GAVE ME AN ESTIMATE OF $300!) they SAY that it is a hardware issue...
However have found more than one website saying that it is most likely the CMOS battery that has gone dead.
Posted on Dec 13, 2008
gnkanang
  • 63 Answers
SOURCE: i've got a compaq presario 1245 laptop. On booting
hi
you will need to open your computer and look inside. if you are not sure take to a repair centre, the battery is on the motherboard, thats why you need to take really if you are going to be doing it. But i would advised to get a IT guy to do it for you. once its taken out you need to replace it with a new one.
Posted on Mar 25, 2009
gymowner
  • 679 Answers
SOURCE: PRESARIO 700 ERROR ON BOOT
If you know how to set up the bios hit f1, if not hit f10, it will boot up and you will need to reset the time and date as they will be wrong. The PCI error refers to a PCI slot, which for some reason isn't functioning properlly. If you run the disk with your motherboard settings that may have come with your motherboard it may just be a driver. If you hit f1 then you will be in the Bios screen. There the keyboard is used to navigate. The mouse won't work, Arrow keys for up down and side to side, and the escape key to get out of a menu or menu item, and enter to select an item. So on the first screen, you will need to adjust the date, time, and year. each time you do this you must hit enter to proceed to the next item. once you get all of the settings right hit f 10, and enter to reboot. So I gave you both ways. If you still have the problem, check the cards that are in your motherboard, there may be a loose one, also try to pop out the battery inside the case, not the laptop battery, if it continues to happen, you may have to pop that little battery that controls the settings for startup, it will reset your saved motherboard startup settings, and once in a while the battery may be bad, which can also cause the kind of problem you describe.
Posted on Apr 20, 2009
Testimonial: "Thank you very much dear Bill"
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Recently acquired a Dell Inspiron 530s, having 2 problems. First, it won't boot right into Windows (Vista), asks to hit an F key (after hitting F1, it goes right into Windows). I went into Setup and a
It's a 'failsafe' - You will need to go back into the BIOS - double check the boot settings - and verify the HDD is set to Auto - make sure the RAM installed is the RAM shown on the boot screen.
Ok, once that is done reboot 2x - hit no keys - if it request F1 to continue, CTRL/ALT/DEL reboot. - go into BIOS, go to boot options find the part that states "stop on error" and disable that... reboot.
If that doesn't help Contact me here. I've other solutions to try as it is a DELL and I've dealt with them for years.
Dec 09, 2011 | Dell Inspiron 530s Desktop Computer...
I have a dell inspiron 1564. To use the f1-f12 functions require me to first hit the FN button. How do I reverse this so that i can use f1-f12 by hitting them directly and have the current commands...
You can change it so you don't have to use the FN key by going into the settings while you computer is booting.
Reboot your computer
Keep hitting F2 until a greay and blue settings screen comes up
Choose the Advanced menu
Use your arrow keys to go down and select 'Function Key Behavior'
Hit enter
Select 'Function Key First'
Hit enter
Choose to Save and Exit (usually F10)
Should fix it up.
Shaun Thomson
Billy Goat Karaoke
Aug 30, 2010 | Dell 0Y3740 Keyboard
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Does not boot. displays intel desktop board in blue screen
Blue error message comes when there is any issue with memory.
First Refix your RAM memory.
Then boot your computer with recovery disk.
For that you have to set first boot device as your cd or dvd rom .
When you power up the computer press F1 or F2 or "del" key then you see bios setup screen.
Then go to boot option and set first boot device as cd or dvd.
Then put bootable disk in computer then it boot with it.
Then follow the procedure on screen.
choose "R" option for enter in "Recovery Console"
Then type in prompt "chkdsk /r"
then it fix error on harddisk then then restart computer then if still same issue then you have to repair your windows with recovery disk.
Let me know if you need more assistance.
Thanks.
Oct 03, 2009 | Intel D845GEBV2 Motherboard
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
I have an older Gateway pc with Bios version 4w4boxo.15a.0017.p12. I added a 512mb of RAM, and when I attempt to boot up I get an error message that says; Error Code 0232: Extended RAM failed at...
I am trying to remember that computer but in most Gateway computers you have to have equal values of ram in the two ports and both must be occupied . I/e two 256 mb.Good luck... Be mucho blessed...Mark
Jun 26, 2008 | Gateway Computers & Internet
Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Mar 06, 2008 | Computers & Internet
BIOS Clock Error
Sep 09, 2007 | Compaq Presario 1275 Notebook
Compaq Evo Notebook N150 Notebook Logo
127 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
