Question about Fujitsu Plasmavision PDS-4221 42 in. Television
Fujitsu plasma vision monitor. Pds42211 red flash 5 times, long number displayed lhs.
Hi. After about half an hour the picture breaks up and the red led flashes 5 times, pause repeat. Also, a long number appears on lhs of screen. After switching off it switches back on ok. The longer it is off, the longer it works before problem. Fujitsu tv have pulled out of uk so no technical backup. Please help me identify where the problem is so I can replace or repair board. Thanks
    Master:
  • 879 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
There is details about the blinking codes to Fujitsu Plasma Display.
Posted on Nov 03, 2012
Testimonial: "Thanks!"
  • Farrel Brenner Nov 03, 2012
    Had found fault, by elimination, to be Video/S-video card. Bought replacement (used) for $30. The link above would have saved me loads of time as it contains fujitsu fault finding info.
4 Suggested Answers
SOURCE: Fujitsu Plasma 42' approx 4 yrs old
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at all_ps2_sales@hotmail.com and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Posted on Dec 21, 2007
  • 534 Answers
SOURCE: Power led blinks red
See recently added Fixya service tip for this model.
Service Bulletin PDP 0068-01 Main Digital pcb see http://www.eserviceinfo.com/download.php?fileid=43450
Posted on Aug 21, 2009
  • 32 Answers
SOURCE: Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Posted on Jul 12, 2010
Testimonial: "Thank you very much, have contacted Fujitsu & am taking screen to them on Thurs, they think power supply & will fix same day if I wait a few hours for it to be tested. Cheers!"
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
Dec 31, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Hi i have a fugitsu plasma tv it turns on and then straight off and light flashes red can u help thanks Mr watch
my tv won't turn on, then clicks on, then off, then on then completely off, it takes an half an hour to turn on
Dec 02, 2009 | Fujitsu Televison & Video
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
I have a 42" Sony Plasma Model# PFM-42B1 was watching tv when picture went out. Red standby light keeps flashing. Was told to unplug for 5 hours then plug back in & count how many times it blinks,...
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 01, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
May 03, 2008 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Panasonic TH50PH10 Turn off Automatically
Hi, if your plasma flashes 10 times it means that there is a problem with the sustain driver. This could be an intermittent problem, such as when the set heats up. It should be returned to the dealer as it is under warranty.
Dec 16, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
hope this helps
Dec 12, 2007 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu Plasmavision PDS-4221 42 in. Television Logo
137 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
