Question about Powermatic Tools & Hardware - Others
Powermatic woodturning lathe 3520a won't turn on.
Won't turn on. When attempted to turn on, inverter registers turning speed, but kicks off and motor never starts. I have unplugged it and left for a while. Same thing happens. Have disconnected motor from inverter and inverter registers speed. When checking for current, there seems to not be current to motor.
  • Shirley Flint Oct 31, 2012
    The error code which registers is "occ"
jgwhomeequip
  • 1902 Answers
SOURCE: the car won't start; lights,
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
Posted on Jun 12, 2011
SOURCE: kodak easyshare m550 won't turn
This is happening to mine as well. I don't know what to do!
Posted on Jun 26, 2011
rickead1
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
heatman101
  • 43501 Answers
SOURCE: Machine won't start brew process. We have
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 03, 2011
heatman101
  • 43501 Answers
SOURCE: Won't even turn on. Was
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 14, 2011
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
Nov 28, 2013 | Powermatic 1352001 3520B 20x35" Wood...
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
How do i go through a used electric lathe motor make sure its good
If it hums when its turned on look at the capacitors. Visually inspect the cooper winderings, if there is any discolored portions, ones that are blackened. It might have burned up a coil.
Oct 09, 2012 | Powermatic 1352001 3520B 20x35" Wood...
My wood lathe is making noise
Thats a good thing, means you making chips. lol. What kind of noise exactly?
I have a 1998 Chevy Cavalier that I can not figure out why it won't start. The following list of parts are brand new: Battery, PCM, Park Neutral Safety Switch, Alternator, Ignition Switch, and finally...
Your car has a sealed transmission, in order to check it you have to go to the dealer or a transmission
shop, its not owner servicable. takes dextron vi, 4 speed 7.4 quarts, 3 speed 4quarts
And as far as the no start, are your plugs getting voltage, if not check your coil, if there is no spark
to your plugs the car will not fire up. good luck!
Jun 26, 2011 | 1998 Chevrolet Cavalier
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Tools & Hardware - Others Logo
77 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
