Question about Keurig B70 Platinum Brewing System B-70
"not ready" after sitting a while
  • kellsarah
    kellsarah Oct 31, 2012
    I have been able to get it to reset and brew by leaving it unplugged for a while and plugging it back in, but when I leave it sitting on the counter on it says "Not Ready" after about 1 hour
  • 1,511 Answers
Let it sit a whle unplugged and restar. Should reset.
Posted on Jan 31, 2014
Keurig b66 blinking not ready
Circuit boad may be defective, retun for replacement.
Jan 20, 2013 | Keurig B66 3-Cup Coffee Maker
Tip
How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be...
How to Convert 2D Video to 3D Video <br /><br />Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. <br /><br />Required Tools: <a href="http://convert2dto3d.net/">2D to 3D Converter</a> <br /><br /><br /><b>2D Video to 3D Video&gt;Step 1: Run 2D to 3D Converter in Video Converter</b> <br /><br />2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. <br /><br /><img src="03e799ef87630e7db329a3d6b4ad32ac.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 2: Click Video Effect Settings button, and Edit button</b> <br /><br />Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. <br /><br /><img src="f54b135b729b8958eb35b3e0b857f22e.png" /> <br /><br /><img src="e870296a85008d2cadfe2edc5c7eaee8.png" /> <br /><br /><img src="3625486fded3ed529ef277b478691616.png" /> <br /><br />All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. <br /><br /><img src="d06d9614161e664378c89f760d88b84c.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 3: Click Start button to <a href="http://convert2dto3d.net/">convert 2D to 3D</a></b> <br /><br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos <br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
on Jul 05, 2011 | Computers & Internet
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Water outlet cracking during installation
if its cracking that means you may have over tightened it. you can not put to much force on it, just snug it down so it does not leak. the best thing to do is snug the bolts evenly on both sides. and make sure thermostat is in the proper way. if you have any more problems, call or visit auto-zone etc, and they should be able to help ! did you clean mounting suface before installing outlet !
Jan 17, 2012 | Cars & Trucks
Says "ready to brew" but says "de scale"
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101=-
Jul 08, 2011 | Keurig B60 Coffee Maker
Change "is lunch ready?" into
when will lunch be ready? I believe. Good explanation of direct and indirect speech found here: http://www.athabascau.ca/courses/engl/155/support/direct_and_indirect_speech.htm
Feb 28, 2011 | Computers & Internet
Jammed fax machine memory?
Our office called the repairman because time was an issue
May 07, 2009 | Office Equipment & Supplies
Keurig B70 Platinum Brewing System B-70 Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
