Question about Indesit Cooktops
How does this attatch to bench
Hi please help I can't figure out where the screws hooks go to attach this to the bench the model us vrm 640 mix
Instruction manual for baumatic cook top
Hi Darren,
Whats the model of your cook top?Here's the manual for a few Baumatic cook top models.
Hope this helps.Thanks!
Please rate this answer.
Dec 01, 2011 | Baumatic Cooktops
We are about to do a kitchen remodel on a high end kitchen and I would like to hear from an appliance repair person what barnds to gravitate towards and also to stay away from.
Hi kevinshields,
Bosch, Gaggenhau & Miele are the best. Ilve is good as well.
From my own experience I'd stay away from any cheap models and AEG (Electrolux falls into that category too) as well as Whirlpool. Parts and availability are the main issue for these models.
Hope this helps
JEDMEYER1
* If this helped you, please rate it
Aug 21, 2011 | Cooktops
Cooktop Model, Maytag JED8430ADB. When I tried to replace the Fan Control Knob, I accidently pushed the Fan Switch and Knob into the compartment below. How do I get the switch & knob back?
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
All 5 ignitors constantly spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 26, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Cooktops Logo
27 people viewed this question
Top Indesit Cooktops Experts
Paul Carew
Are you an Indesit Cooktop Expert? Answer questions, earn points and help others
