Question about Dishwashers
Rylee, You are awesome. On the KUDS01DJSS0 the manual says to hold the button for 3 to 5 seconds , you said 10 to 15. 14 seconds was the trick. Thanks for saving me a headache (browbeating for new dishwasher)
5 Suggested Answers
SOURCE: Dishwasher AEG FAV40620W stuck time delay
Thanks. I figured it out from the online manual. Hold buttons #2 and #3 (second and third button down on far left side) for 2 seconds should reset it. It took some 15 minutes however before the dishwasher reset!
Peter Smith
Posted on Jan 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire dishwasher
Hi!
The timer switch i was talking about was the selector switch/cycle selector switch. And in your case the timer is embedded in the control panel, so you need to get it replaced.
If you have found this information to be valid and useful, a "FixYa" ratings would be appreciated. That is the only reward I get for the help I offer here.
Thanks
Rylee
Posted on Jan 29, 2009
klipsan
  • 64 Answers
SOURCE: KITCHENAID DISHWASHER SUPERBA MODEL KUDS01DJSS0
The easy solution is to try pressing the Energy Save Dry button & hold it in for 3-5 seconds. This should turn the child lock on & off.
If this doesn't work, then it's likely that one of the pads on the control panel is stuck, and it (the control panel) will have to be replaced.
If you don't have the manual, you can download one here (PDF format). Good luck!
Posted on Mar 02, 2011
  • 899 Answers
SOURCE: Dishlex Global 300 Dishwasher -
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Posted on Jul 26, 2011
Testimonial: "Excellent info - saved me a packet"
KITCHENAID DISHWASHER SUPERBA MODEL KUDS01DJSS0 CHILDLOCK DOES NOT OPEN .REMAINS IN LOCKED POSITION EVEN AFTER POWER RESET. CAN'T USE THE DISHWASHER.
Mar 02, 2011 | Dishwashers
Control locked light on
Hi
If its a Whirlpool washer then to unlock it press and hold the END OF CYCLE button for 10-15 seconds and if its a Kenmore then press and hold the DRAIN/SPIN button for 10-15 seconds. Please post a comment if you require further assistance.
Thanks Rylee
Oct 29, 2010 | Washing Machines
Control lock light is on--how do I get it to turn off--unplugging did not help--pressing the start for 3 seconds did not work
Hi
Thanks for using FixYa. To unlock the controls you?ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Kenmore Washing Machines
Control panel locked. How do you unlock it? Cant find manual.
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked How can I get this unlocked so the washer will wash again.
Your owners guide will advise you what buttons to push to get out of the conrol lock (child lock) function. Usually the console will also show you which button or buttons to press by holding them down for 3 seconds.
Aug 29, 2010 | Whirlpool Washing Machines
Cant figure out how to unlock control lock...can't find manual...
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the OPTIONS & SELECT button together for 15-20 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | GE WSXH208A Front Load Washer
How do I turn off "CONTROL LOCK" light?
Hi
Thanks for using FixYa. Assuming that it is a Whirlpool Duet Washer you’ll need to press and hold the END OF CYCLE SIGNAL button for 3 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 18, 2010 | Whirlpool GHW9250M Front Load Washer
Control lock light
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Controls are Locked and wont unlock
Press and hold 'dry' & 'spin' that should unlock OR Try holding the "end of cycle" button down for 5 seconds.
Jun 14, 2010 | Kenmore 42822 Front Load Washer
Answering Machine language change
I had the same problem last week. I had to call GE to get it resolved. Hold the skip button done a few seconds and it should change back to english.
Feb 12, 2007 | GE 25861GE3 Phone
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
