Question about Whirlpool GHW9100L Front Load Washer
Shakes On spin it shakes so bad I have to turn it off.
    Genius:
  • 2,920 Answers
The balancer inside the machine is out of alignment youll need to have someone look at it
Posted on Jan 04, 2009
I have a whirlpool washer sm9280469 that shakes bad on spin
not a good model number,if it's very loud in the spin cycle the spider gear is bad and you need a new washer,watch video
http://www.youtube.com/watch?v=Uud3xDus4TQ&feature=related
Mar 28, 2013 | Whirlpool Washing Machines
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Steering shacks replaced steering damper still shacks
shakes?or shacks?Let's just say that you mean shake.If your brake pedal pulsates,replace the rotors.If your steering wheel shakes(low speed)broken belt in front tire.Jack up one tire enough to clear the ground,spin it.Spins nice,lower and jack up the other.Spin that one,if the belt is broke it'll be very noticable.While up in the air check the lug nuts,if they're loose it can make the steering shake too.If the shake is at highway speed,bad shocks or tie rods or ball joints or a combination of these.Jack up a front tire and try to move it(Key turned off to lock steering).If it moves top to bottom,ball joint.Side to side,tie rod.Doesn't move,shocks.The worst could be a bad hub bearing,but you'd hear it and you said nothing about any noise.
Nov 05, 2009 | Harley Davidson XL 1200 C Sportster Custom...
Shakes on spin cycle
yes bad struts can cause this problem also if you have it on carpet you would be better off cutting a piece of plywood for it to sit on as it will shake when sitting on carpet most of the time
May 19, 2009 | Maytag Neptune MAH7500A Front Load Washer
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
LG wm1832cw shaking bad in spin after move
manual,,lg.com...but befroe youdo that,,put the unit in spin ,,get a small wrench or the wrench that came with the installation pack..now when unit goes into high spin the fastest spin,,tighten the lock nuts on the legs one at a time dont turn the leg itself,,just the lock nut on the legs,,it might take two spin cycles but you will get it ..tighten all the way uop to the base,,,onthejob
Jan 09, 2009 | Washing Machines
Won't agitate and makes a grinding noise
hi thanks for the question yes it is a bad transmission sorry
Sep 25, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
