Question about Samsung Computers & Internet
How do i change the settings on the laptop samsung np 519 keyboard the letter k is 2 at moment
  • Samsung Master
  • 27,725 Answers
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Posted on Nov 01, 2012
4 Suggested Answers
SOURCE: I have a samsung NP-R60Y Laptop which has become
Boot from Windows Install DVD, when you get to Format, do a FULL NTFS format, delete the Old Windows Directory and install it all again.. that will return to the "Factory" condition. Then when at desktop first time, install antivirus, and do all Windows updates, before you "Surf: the 'net.
Posted on Feb 28, 2010
kornho
  • 781 Answers
SOURCE: On my laptop in green are symbols and numbers, for
if you press the L key and the number 3 comes up. you likely have the num lock on.
is different for every computer but usually you can deactivate the num lock by pressing 2 keys at the same time.
the fist key is usually the key labeled (Fn) and the other key is usually a function key (the ones with F an a number), the way to find which is the other key is to look at the keyboard and try to find one that has a simble that looks like a tiny numerical key-pad
press both keys and a light that signals that the num lock is on should go off. at that point you should have your l and any other letters again typeable.
good luck
Posted on Mar 30, 2010
Testimonial: "Thank you very much. I never would have thought that had anything to do with the other keys."
bronk50
  • 27725 Answers
SOURCE: samsung laptop np-r519 password locked
Which operating system ?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Posted on Oct 24, 2012
Samsung np-r719 keyboard not all keys work and they all give different character to key pressed? Have changed keyboard but still the same
did you select the right settings for the keyboard?
an usa style keyboard and not a chinese or japanese one?
you understand what i mean?
Jan 21, 2015 | Samsung R530 R540 R719 R728 Rv510 Keyboard...
Samsung n130
Have you tried downloading the audio drivers for the computer?
http://www.samsung.com/ae/support/model/NP-N130-KA01AE-downloads?isManualDownload=true
Apr 18, 2014 | Computers & Internet
Laptop key popped off
restart everything(each part) individually
Feb 16, 2014 | Samsung Q430 Laptop
Keyboard removal
If you are using laptop, you will find interlock kinda thing at the edge of the keypad/keyboard. Just remove it by unhooking, clean it and then hook it back.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
May 01, 2013 | Samsung NP-RF511-S04US Laptop Computer -...
Samsung N130 keyboard not typing some letters and other letters type numbers
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Apr 20, 2013 | Samsung NP-N130-JA01US Netbook
Samsung q45 keyboard intermittant
Try adjusting the keyboard input speed.
Go to Control Panel - Keyboard - Speed tab then adjust the speed settings.
Apr 06, 2013 | Samsung Q45 Notebook
My samsung N145 is has a problem with the keyboard.when i type u it shows 4,when i type i it shows 5,type / it shows ,type m it shows 0,type k it shows 2.whats the problem???
The keyboard needs to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to keyboard. Hook a external keyboard to make sure.
May 13, 2012 | Samsung Computers & Internet
Delete key on laptop not functioning
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard, if no change! there is a device drive issue, do a system restore of your computer back to an earlier time before this happened.
Mar 11, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Hello, I am looking for the basic instructions for replacing the keyboard unit on a Samsung NP-R720 laptop. I am not a computer novice ! The first computer I owned, I built in 1983, but there can be some...
First, not that the keyboard is held by two long screws (as marked in the picture below), which are to be opened from the bottom.
After removing the battery and bottom screws, you have to remove the top cover (near LCD hinges, above keyboard). After that you would be able to pull the keyboard and remove the connecting ribbon cable to detach it. Below is a video for Laptop keyboard replacement.
Also, have a look at some Similar Laptop Disassemble Guides
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | Computers & Internet
Samsung Mobel NP-P500Y
What sign is it that it gives you? your keyboard may be set up for the wrong region. are all the signs like that? or just the @ one? In Windows XP to change the keyboard layout: Control Panel -> Regional and Language -> Languages Tab -> Details and the keyboard language should be English US.
for more details visit this website: http://www.starr.net/is/type/kbh.html
Hope that helps!
Caleb Scansen
Technician/Manager
Rimrock Computer Co.
2320 Zoo Dr. Ste D
Billings MT 59101
Feb 28, 2008 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
