Question about Chevrolet 1969 Chevy Camaro Z/28 1/18
69 Camaro Turn Signals not working
My turn signals do not work on either side front or back but I turn on hazards and both front and back flash
    Sergeant:
    Champion:
  • 241 Answers
Check relays and turn signal-flasher. flasher for turn signal is separated to the hazard flasher.
Posted on Nov 16, 2012
My rear turn signals are not working. front turn signals work rear parking lights work brake lights work
In the diagram for rear lamp, the top wires are voltage, the bottom black wire is ground. The brown wire on either side should be tail lamps, goes hot when you turn on the headlamp switch. The other top wire on either should be for turn signal. With everything turned on, is there voltage on that wire?
Because the front works and the rear don't, possible wiring circuit problem? The voltage for turn signals comes from bcm. The bcm knows when you turn on turn signal switch, either side, then the bcm sends voltage to turn signal lamp at the rear and front.
Oct 17, 2016 | 2009 Chevrolet Chevrolet HHR LS
My turn signals sometimes will quit working then I have to hit the hazard lights button leave it on and then turn my turn signals on then they work what causes this to happen
When the turn signals quit working pull up , down , front to back an back to front on the turn signal switch handle . Do they work when doing this ? Pontiac had bad switch . The power for the turn signals goes through the flasher / hazard module . Could be the switch or the module.
The HAZARD LPS fuse in the left hand instrument panel (LH IP) junction block supplies battery positive voltage to the flasher module, which is part of the hazard switch assembly. The TURN LPS fuse in the LH IP junction block supplies ignition positive voltage to the flasher module. The turn signal lamps may only be activated with the ignition switch in the ON position. When the turn signal switch is placed in either the left or right position, current flow is from the flasher module's output to the turn signal switch assembly. The flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators.
Mar 12, 2016 | 2001 Pontiac Grand Am GT
I just bought the car the turn signals work in the front but not in the back whats the problem?
Have you checked the bulbs already?
Don't know what kind of car you are dealing with here.
Most vehicles - the brake lights and rear turn signals share the same electrical circuit to the rear tailights. Usually the turn signal switch will separate which signal goes to the back.
Do your brake lights work? Is there a High mounted stop lamp and does it work?
I have seen a Hazard Switch be ON and fuse blown causing the Hazard Flasher to be inop - which prevented the turn signals from working. Turning OFF the hazard flasher brought back the T/S.
Check the rest of the lights - see what does and doesn't work - and do the front turn signals flash? Stay On? Or flash really slow?
Let me know what you find out and if this helps you at all.
Mar 12, 2015 | Cars & Trucks
Turn signals won't come on inside or outside of car but hazard lights come on inside and outside of car
Check turn signal fuse, if fuse is good, check turn signal flasher, this is identical to hazard flasher, I believe on the 1997 it is located under the dash near the center console. The turn signal and hazard flashers are the same part number so try switching places with them and see if the turn signals work. If turn signals work after switching them you need a flasher.
Nov 09, 2009 | 1997 Chevrolet Camaro
Driver side signals only work when headlights are OFF
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
Apr 22, 2009 | 2004 Dodge Intrepid
My hazards in my 1997 camaro rs work, but the back and front turn signals dont. The lights for the signals dont work in the dash either, just the lights for the hazards
check the signal flasher ( little silver or colored can in fuse panel or under dash. 4 ways have 1 flasher and the signals have a seperate flasher. Put hazards on to hear click, to determine which flasher is which. Hope this helps
Apr 13, 2009 | 1997 Chevrolet Camaro
No turn signals
they are seperate flashers. most times they are both on fuse block or clipped along the metal inside edge of the lower part of dash. Don't count on that. if someone changed it once, it could be tucked into wiring somewhere.
Feb 06, 2009 | 1994 Chevrolet Camaro
Turn signal
If both front turn signals don't work, there a chance that you have a problem with the relay. It doesn't sound probable that both of the bulbs blow at the same time.
Eitan.
Jun 10, 2008 | 1997 Chevrolet Camaro
Chevrolet 1969 Chevy Camaro Z/28 1/18 Logo
335 people viewed this question
Top Chevrolet Toys Experts
gbob59
jeff5may32
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
