Question about Xerox 6010 Memorywriter Electric Typewriter Mfr P/N 6010-07
XEROX 6010 NOT ERASING
Correction tape is not being lifted high enough, erases bottom half of letters only.
  • Xerox Master
  • 3,594 Answers
The adjustment on the L/O is a little tricky for the novice you probably need a tech.
DickyO
Posted on Nov 06, 2012
  • dick davis Nov 08, 2012
    Thanks Dicky-O, I found a lifting arm was bent, straightened it out and works great.
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Erase old videos
Ideally, you'll get a high-powered bulk tape eraser that is designed for video tapes and will work perfectly for audio tapes, as well. An audio tape eraser will work to a point, but usually won't blank them out completely since it doesn't put out a strong enough electromagnetic field to erase videotapes completely. I personally own an old Radio Shack high powered eraser and it works to erase both video and audio, as well as a demagnetizer for old color tv screens (when used at a distance...a bit too strong up close), and demagnetizing screwdrivers (the ones I don't want magnetized, that is). Hope that helps.
Apr 11, 2014 | Sony HI8-MP Hi-8 Tape
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
Wheelwriter 2 correction ribbon lift adjustment nost high enough
Check that the lift off is properly attached to the ribbon and ribbon is installed properly, If the liittle tabs on the L/O cassette are broken you can use a piece of tape to hold them together.
DickyO
Apr 10, 2013 | IBM Lexmark Personal Wheelwriter 2...
Hello, The correction ribbon does not raise high enough to erase any text. It raises just enough to catch the bottom part of lower case g, j, etc. Any help with this issue would be appreciated. Thanks...
Underneath the ribbon cassette base on the RHS there is access to a small "phillips head" screw. Remove the ribbon cassette, move the carriage to the LHS,POWER OFF. Loosen the screw, do not remove it or you will have a hard time getting it back in....once loosened, lift the cassette base up or down to the required position, tighten the screw. re-install tape and try machine...adjust as necessary.
Sep 23, 2010 | Nakajima AE-710 Typewriter
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
Correction ribbon does not lift high enough to remove letters.
sounds like lifting cam is out of sync.will need tech. to repair. you can call brother for your nearest service center.
Oct 30, 2009 | Brother SX-4000 Typewriter
Cutting off bottom of letters
Look at the ribbon and see if the letters are in the center of the ribbon. If not you have a ribbon lift problem. If they are check to be sure the platen is fully seated in the side frames.
DickyO
Nov 21, 2008 | Brother SX-4000 Typewriter
Xerox 6010 Memorywriter Electric Typewriter Mfr P/N 6010-07 Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
