Cant figure out where the screws hooks go to attatch this to the bench
Diagrams are unclear and none of the holes in the bottom seem big enough for screws
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
What part? What is the model number?
Posted on Nov 01, 2012
Any advice on cleaning out a screw hole for a storm shutter?
how big are the holes?
maybe a pipe stem that cleans out a smoking pipe might
help
Jul 31, 2017 | Miscellaneous
How do I remove the water tray on a Bunn B10B?
You can verify whether there are screws in the holes, by using a bright light for illumination and peering inside. If there are phillips head screws in the holes, you may need to use a metric screwdriver to remove them. The cross slots may require this.
Nov 27, 2013 | Bunn BT10B Coffee Maker
Insinkerator cover control problems
sometimes there are 2 places to attatch wires on a switch, there are the screw connections, and sometimes there is a hole in the back of the switch. if nothing else, attatch a jumper wire from your hot wire of light switch, to hot terminal of insinkerator.
Oct 14, 2013 | Electrical Supplies
Ryobi CS26 Trimmer/Edger: how to replace the pull cord. I cant get it back together. I took it apart and cant get the front section to go back together and get the bolts back in. Something is not aligned...
There is a screw hole on the bottom of the recoil spring. It needs to be lined up with the same hole on the bottom of the gray plastic casing.
Jun 20, 2011 | Garden
No place to screw the faceplate onto
On your mixing valve, Your hot and cold water should hook to the valve at 9:00 and3:00 positions. You should have two ears at 12:00 and 6:00 positions which are used to screw the faceplate on. If you don't see these ears, the hole that the valve is in may not be big enough for you to see them. If it is tile, they may be covered with tile. If it is fiberglass, you would usually would have an oblong hole, longer at top and bottom, to see ears. If it is fiberglass, you may want to drill through where screws go, and through bolt your valve so it is tight. The hole in tile and/or concrete should be oblong so you can see screw holes.
Apr 21, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Changed brake booster and mastercylnder on 2005 medium pickup , cant get any pedal to stay after bleeding ?
did you hook the big vacum line to booster back in?the master cylinder came w/bench bleeder, did you bench bleed the master cylinder? if not, thats the problem. you'll need to take back off @ bench bleed that master cylinder.
Aug 18, 2010 | Chevrolet Chevy Cars & Trucks
Is there a secret to replacing gas lines on a trimmer? my new lines seem too big and don't want to fit into the hole
Yes, the lines should be larger than the hole or they will leak. The last thing you should do is drill the hole bigger!
First cut the end of the new line on an angle and push it throught he hole as far as you can. Then with a long set of hemostats reach in through the fill hole and grab the line and pull it up through the fill hole. Cut the line straight then and attatch the fuel filter and push it back into the tank. Next, pull the excess line back out of the tank until the filter lays nice and flat on the bottom of the tank and you are ready to cut your new line to length and attatch to the carb or primer bulb.
Hint: always purchase more fuel line than you think you will need. That will give you excess to play with when cutting your angles and pulling it up through the fill hole.
Dec 28, 2009 | Craftsman 25cc Gas Line Trimmer
The door flips down for loading. The cables
bottom interior part of the dryer has two small holes the spring attatches to
Aug 17, 2009 | Kenmore Dryers
How to convert Pooh Days of Hunny Activity Center Exersaucer
Ok take the legs off of the top part (white) just twist and the top part comes off; then twist the springs off. Now take the legs that you took off and slide them through the first hole of the bottom from the bottom not the top; do all three legs and you have a table.
You can pop off the toys the tigger and flower one you have to push the thing till you have a big enough for it to slide through.
The disney pooh car pops right off of the top part; then you just unscrew the car from it's bottom (2 screws) take it off the track and volia you have a car.
I bought mine from someone but with a little bit of imagination I figured it on my own. lol.
Jun 16, 2009 | Evenflo Generations
How to attatch 7" Pelican Game Glass to slim Ps2
Slim PS2s have to holes on back left and right. The far edges one lower right hand side of the power plug and another on the upper left side of the fan exhaust. Hard not to notice. I've never actually noticed they were screw holes I figured they were just... holes. Hope this helps.
- Xero Necross
Dec 26, 2007 | Sony PlayStation 2 Slimline Console
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
