Tower not coming on
I shut down my tower and then disconnect all cords to clean and when hooked eveything back tower will not power up. Dont know if i actually there is somethign wrong? Had this problem befor when i lost power and unplugged everything and let set and then it worked later. Is there something internal that has to wait like a reset button?
  • scott1211966 Jan 04, 2009
    when you push the power button ,there is no light that comes on or anything
    Scholar:
  • 86 Answers
Check the power supply, if you don't hear any whir at all from the fan, power supply needs to be replaced.
Posted on Jan 04, 2009
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
Pavilion Elite M9040N tower shuts down within seconds when I hit the power button. Blue light flashes 2-3 time and it shuts down. When I remove the processor ( Intel Q6600) unit stays on and when I pull...
Hi.
Before you go and get a new motherboard, first let's try to do a hard reset.
Sometimes, hp and Compaq computers bios will lock up, causing this condition.
To do the hard reset, first make sure all the cords are connected to the points where they belong.
Now, unplug your ethernet cable, and your power cord.
This stops all power from coming into the machine.
Next, press and hold the power button in for 30 to 45 seconds.
This causes the capacitors on the motherboard, and the ones in the power supply to dissipate, and returns them to a ready state.
After doing that, reconnect just the power cord and attempt to power on the computer.
If it boots, then it was the bios glitch, if not, then you have a faulty motherboard, that or you have a device installed the wrong way, so that when the system boots up, it calls for the power to that device in an unusual way, then the system will shut down to prevent damage.
If it does boot up, then you can reconnect the ethernet cable back, otherwise there is no sense of hooking it back up as you would be replacing the motherboard anyways.
I hope you have good luck with this, and have a good day.
May 07, 2011 | Computers & Internet
I turned off the computer by going to shut down earlier today I went to turn it back on this evening and the CPU won't turn on
hello, make sure nothing has come unplugged and that none of the buttons are stuck on. With that said if this is an older pc, your power supply inside the case might have went out. power supplies go out quite often, replacing them is not to bad just make sure you have the correct physical and power size. Also verify that it has the connectors for that particular motherboard.
hope this helps
Jan 14, 2011 | HP Pavilion a6650f Desktop PC
My toshiba laptop's screen shut down suddenly while i was playing a game, now i cant turne it on , i dont know what to do?
  • Disconnect all the power supply (battery and power cord) and attachments.
  • Press and hold down the power button for 30 seconds
  • connect with the power cord only
  • restart the computer
It seems the video card is not supporting the game's video requirement
Sep 24, 2010 | HP Pavilion dv6000t Notebook
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
Melting plastic smell/ computer slow and shuts down after about 15mins
Hi there.
The reason you can smell burning plastic and why its shutting down after a short time is because its overheating. This can be caused by a build up of dust on the CPU fan, overtime with dust build up computers struggle to keep themselves cool and tend to shut down unexpectedly, chances are this is the problem with your machine, my advice would be to remove the power cord, open the side panel of the computer and clean all the dust away from inside the tower, do this with a soft, clean paintbrush making sure you remove the dust carefully and gently, also make sure the CPU fan and the heat sync behind it is completely free of dust or any other foreign objects.
Once you are happy that its clear of dust, close or return the side panel, plug in the power cord and turn the PC on, you may find that the PC will stay on for longer with the smell dramatically reduced.
Please post back with the results and thanks for using FixYa!!
May 22, 2009 | HP Computers & Internet
Can't access desktop, windows won't load so pc won't shut down
Hold th epower button down on your tower for about 5-10 seconds and it should shut off. Then you can turn it back on. If that doesnt shut it down you can always pull the power cord.
Apr 09, 2009 | E-Machines T3958 (827103050974) PC Desktop
Presario s4020wm tower
start with the power supply and verify that it working if not replace the power supply with one that is known to be good then if you still have no power check to see if the voltage selector is set to 115 not 220 if this all checks out good than you will need to verify that all the connectors to the motherboard and all drives are secure i have got a lot of dead computers to come alive just by unhooking the power cord to the computer and opering up the tower and 1 by 1 unplugging and replugging in all the wires to the board and harddrive and cd rom and dont forget about the cmos battery and than pressing the power button for 3 seconds than plug in the power cord to the computer and try to restart ok good luck !!!!
Aug 07, 2008 | Compaq Presario 5000 PC Desktop
How to install a dvd burner
First you shutdown your computer, then disconnect all power cords. I don't know if you have a tower or a deskpro, with the tower just slide the panel out pulling from the back, you may have to remove a piece from the front with a tower. Pay attension to how your cd rom is hooked up, I don't know if this is a combo (cd/dvd/RW) if it's a combo, if it is a combo you would have to take out the old drive and replace with the new, just pay attenion to how the old drive is hooked there should be two cords to connect to .  If there separate drives there should be an empty bay.  Let me know how your doing, and if I can assist you more.........Thanks, Heidi
Oct 19, 2007 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
