Question about Singer Insta-load 16mm Movie Film Projector Works Vintage Photography & Case Lrg
Can't get sound on my singer instaload projector
No sound but everything else works great
I am haveing the same troubles here .
I am going to take a look at mine when I find out what is going on and how to fix the trouble Ill let you know
from will
Posted on Apr 09, 2015
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Dec 08, 2012 | Toshiba TDP-S8 Multimedia Projector
Both red warning lights on the projector are blinking.
how about the fan does it works, then clean the filter.
Jul 18, 2012 | Office Equipment & Supplies
Singer 774 - Clanking on Zig Zag Settings
I would suggest taking the machine in to have it checked, when a '
machine is taken for yearly check ups, the machine will run better
& not be a cause of worry
Jun 03, 2012 | Singer Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
I have a kodak 5600 slide projector. Everything was working great and when I changed the carousel the slides wouldn't fall to be viewed or would fall half way. This projector is almost new even tho it...
It sounds like you need the timing adjusted in the projector. The pressure pads that hold the slide vertical in the projection gate are closing too soon. Check the Kodak website for the service procedure for this adjustment. If you need assistance, contact an authorized warranty repair dealer. Good Luck !!
Jul 14, 2011 | Kodak Office Equipment & Supplies
Everytime I open the Singer Software the following message is comming up: The procedure entry point ?Splash_TextColor@@YAXK@Z could not be located in the dynamic link library CF_Splash.dll.
The Singer software is cr..... It's loaded with a bunch of junk. The best thing you can do, seriously, is go into your control panel, remove all of the software from the PC (keep the USB cord unplugged from the sewing machine) and reinstall EVERYTHING.
If you aren't clear on any of the steps of what you have to do, please post a comment back to me. I'm not only an avid sewer, but am pretty computer savvy. I'll be happy to take you through the steps to get you back up and running. I have a CE100 myself and troubleshot people running Windows 7 without the 2.5 Futura upgrade on their PC's to get their Futura's running. I'm not great, but I am pretty good. We'll get you embroidering in no time and to heck with the lack of Singer's support!
Jun 15, 2011 | Singer CE-100 Futura Computerized Sewing...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
G7 just dead. can't turn on power. check battery
These G7 powershot cameras sometimes get a short from a loose screw which often leaves the camera with no power. You'll want to have it fixed but with a place that knows of the problem and does the correction inside the camera so that it doesn't keep happening. The place that just does powershots and they do amazing work on these cameras is: www.camerasandparts.com They charge about half of what canon wants to fix this problem and the include the service and the correction to the screws inside so it won't keep happening. It's $89 for everything with them, a great deal and they do superb work on these cameras.
Feb 27, 2010 | Canon Camera Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Singer Insta-load 16mm Movie Film Projector Works Vintage Photography & Case Lrg Logo
748 people viewed this question
Top Singer Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Singer Office Equipment and Supply Expert? Answer questions, earn points and help others
