Question about Philips 50PL9126D/37B 50" DLP TV
My phillips is making a loud buzzing noise, no picture, then it shuts off
TV has loud buzzing/humming noise when turned on with no picture (snow) but sound. Then it shuts itself off.
  • 1 more comment
  • Dennis K. Rogers Nov 01, 2012
    I now believe that I have a bad color wheel and will verify it this weekend. Where do I get a good buy on a new one?
  • Dennis K. Rogers Nov 03, 2012
    I confirmed that it is in fact the color wheel as a couple of sections are shattered. I have search the web for a replacement with no luck thus far.
  • SD Tech
    SD Tech Nov 03, 2012
    If google did not reveal it , it may (good old Philips) be available with the optical engine which may not be available
    Top Expert:
  • Philips Master
  • 14,553 Answers
Presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Posted on Nov 01, 2012
3 Suggested Answers
  • 1039 Answers
SOURCE: Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Posted on Apr 25, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: no picture, humming
lost the lamp, replace lamp
Posted on Jul 07, 2009
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips Televison & Video
TV Making a Loud Noise
this can happen with the flyback transformer's brightness which can be adjusted , also the power transformer can make humming or buzzing sounds which can't be adjusted , also this can happen with the picture tube or the CRT board failing , and sometimes chips with heat sinks or the IC's themselfs
Oct 07, 2008 | Symphonic ST420FF 20" TV
Noisy phillips TV model tr 2503 c121
Mine does this too, just bought it yesterday and noticed the sound this morning, I guess because the house was quiet, now it's the most annoying noise ever. I have been searching for solutions all day, one forum said to go to the picture settings and turn the light sensor to "OFF"...Haven't gotten home to try it yet, but I hope this helps BOTH of us!
Nov 28, 2007 | Televison & Video
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Philips 50PL9126D/37B 50" DLP TV Logo
469 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
