Question about Whirlpool Dishwashers
Whirlpool adp4502/5 not starting wash cycle,keeps pulsating.
2 Suggested Answers
  • 62 Answers
SOURCE: whirlpool d/w is stuck on wash cycle
Is it filling and emptying at the same time???? If not could be a heat problem. How long do you leave it running for?
Posted on Jan 03, 2008
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
Whirlpool washer model wslp1100d after the rinse
Hi Derek.
There are several different problems that may result in basket wobbling and machine shaking heavily during the spin cycle. Sometimes the shaking can result in spin cycle not ending, like in your case.
To find out what the problem is the washer must be taken apart and the tub removed.
A common situation is given by a defective drive hub.
At the end of this comment there is a movie showing how to reach and replace the drive hub in whirlpool top load washers. In this washer you will find a more complicate device instead of the hub shown in the movie. There is a pulsator, the balancer and other parts that must be inspected. The two assemblies are indicated respectively as part 52 and 56 in diagram nr.1 below. Here the part list: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470626#d26470626
If you find a foreign object such as a cloth below the tub, then that can be cause for the shaking and wobbling.
If the parts below the tub are OK, then one of the suspensions may be broken. Suspension (damper) is indicated as part 36 in diagram 2. Here parts: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470625#d26470625
Here diagrams:
Diagram 1
Diagram 2
Here the video:
utube.png You-Tube video "aj-HSUOuBBA" placeholder (do not delete) utube.png
Regards.
Ginko
Nov 20, 2011 | Washing Machines
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
Washer gets to 20 min left in rinse cycle recuriculation pump comes on and off anything from 5 seconds to 2 min control countdown stays at 20 min for over 20 min? whirlpool calipso
usually problem with digital washing machine is on the program module, exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hoseline.
Jul 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Pulsating water in the hot water cycle
id be curious as to the age of this machine, because the newer models have what teh call adaptive water temp sensors that will optimize the water temp automatically.. your hot water may be "too hot" and your cold can be "too cold" and the valve corrects to a preset temp. this sounds like whats happening
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Dishwashers Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
