Question about KitchenAid Kitchen Ranges
KEMS378 microwave not heating
KitchenAid Microwave oven combo Microwave portion NOT heating.
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 126 Answers
SOURCE: replacing only the microwave in Jenn-aire oven combo unit
i dont think so i would check around
Posted on Dec 10, 2007
  • 5 Answers
SOURCE: oven and microwave combo
Your microwave is plugged into an outlet built into the top of the oven. This outlet has a "circuit breaker" that trips when using the self cleaning feature. This is a design flaw that Jenn-Air/Whirlpool refuses to acknowledge. You just need to reset the breaker button that the microwave is plugged into. It's right next to the outlet.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
I have a kitchenaid 27 oven and microwave combo, the bottom element burned out. I replaced it but it doesn't heat up. Any help. Ty.
When it burned out, it may have also shorted out, so you should check to see if there is a fuse in the circuit to the element.
Aug 23, 2014 | Microwave Ovens
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
There is a superba 27 Microwave/Convectionand U Oven Combo in my house. The Micro Convection part is Part 3179901 and the Model in the oven portion is listed a s KEMS376TWH1. I only have a cheat sheet ...
Mommakat45
You can find the manual at
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS376TWH1&siteCd=KAD&userType=Consumer
Dec 12, 2010 | KitchenAid Microwave Ovens
I have a KitchenAid microwave/oven combo unit model KEMS308. When the oven is on, there is a lot of heat blowing out of the space between the oven and the microwave (microwave is on top). My husband...
That is where the vent is. You should feel some hot air there. If you do not feel the air that is the time to worry. If you have any other questions please feel free to ask.
Jan 01, 2018 | KitchenAid Architect® KEMS308S Electric...
I have Kitchenaid Combination wall Oven and Microwave Model #KEMS308SSS and my microwave runs fine but dose not heat any thing and starts cooling for few mins
I have the same problem with a KEMS378 KitchenAid that is only 11 months old. Gettign warranty repair Monday...So can let you know...
Jun 20, 2010 | Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
Have had this oven for 8 years. At least three times, usually after using the clean cycle in the main oven, the latch mechanism has broke and the oven door will not open. In March they installed a 'new design' to prevent this. It's seven months later, and it broke again. Has anyone had similar experiences? How did you resolve?
Aug 27, 2008 | KitchenAid Architect® KEMS308SSS Stainless...
Kitchen Ranges Logo
79 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
