Question about Canon PIXMA MP750 All-In-One InkJet Printer
No Power but awful 1st noise
This printer/copier etc.. will not turn on, when I unplug from outlet and replug the cartridge spinner (I suppose)makes a horrible noise like something is holding it back then after a few seconds the cartridge lifts and slides as it is preparing to work normally. Again, the power button will not turn on machine otherwise??? Heide
  • 685 Answers
Have you checked to make sure there is nothing stuck in it?thats what i would do first.
Posted on Jan 04, 2009
All the lights are blinking and when I tried turning the computer off and then back on, the part that holds all the ink cartridges went back and forth and then went all the way to the left and made an...
unplug printer,access the catridges,remove all the catridges,replug machine in till carrier comes back into normal position,refit catridges propely,try printing
Nov 01, 2013 | Epson Stylus 2200 InkJet Photo Printer
Have Lexmark 4200 series all-in-one center. I just replaced black cartridge (71) and it keeps giving us an message - Black Cartridge Missing. The tape is off, I've unplugged it, I search for the #71...
It could be that your cartridge needs some cleaning or the cartridge is not seated properly in the carrier. Open the printer cover. Remove the cartridge and wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. Close the printer cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert the black cartridge and make sure it's properly inserted.
May 20, 2011 | Lexmark X4270 All-In-One InkJet Printer
I am having alignment issues with my x2670 printer
What are the versions of your cartridges inserted in the printer? Open the printer cover and remove both cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert both cartridges and make sure they are properly inserted. Check for any errors. If error continues, please contact Lexmark technical support for additional assistance.
May 16, 2011 | Lexmark X2670 All-In-One Printer
Cover open sensor is knocked off the switch assembly - Please show and tell me how I can repair it.
Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset it. When the printer turns on, reinsert the cartridges. Make sure the cartridges are properly inserted in the carrier and the lids snap in.
Source: Error: 'Cover open, please close the cover'
May 08, 2011 | Lexmark X6570 InkJet Printer
Error message is Alignment Problem, but the cartridges have no clear tape on them...and have been printing with these cartridges for a while. They are not empty
Try to remove the cartridges from your printer. Check the cartridge area and make sure there are no debris or obstructions in the cartridge carrier path. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert one cartridge first. Close the cover and check for errors. If none, reinsert the other cartridge. Check for errors. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
Apr 29, 2011 | Lexmark X4690 Wireless InkJet Printer
My printer error message indicates- Alignment problem.(1) Remove tape from cartridges.(2) Check Paper.(3) Press Ok to retry. I do not see it being easy to remove tape from cartridge,but my allignment paper...
Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
Apr 11, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Hi, my printer keeps saying cover open even though it is not have opened printer up but do not know which way back to put the white piece thanks
Remove the sheets of paper. Open the printer cover and remove the cartridges as well. Close the cover. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Load some paper. Check for any error. Try to print.
Apr 11, 2011 | Lexmark X3480 All-In-One Printer
I just put in two new cartridges but my print is still pink instead of red and green is coming out blue.
Run the printer utilities, clean the cartridge nozzle, align the cartridge and deep cleaning of the cartridge until you achieve the right color printout.
Nov 10, 2010 | Canon PIXMA MP470 All-in-One Printer
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Canon PIXMA MP750 All-In-One InkJet Printer Logo
100 people viewed this question
old marine
old marine
Corne Viljoen
