Gnerator has dropped in output
My genertaor was woking perfectly fone tonight for my catering trailer. I run small desk top fridge, under counter freezer, florecent strip light, small ipod docking station, and kettle. I was sitting there everything was fine, put kettle on and the generator as normal deepend in sound as works a bit harder with the kettle. Then off everything went. I checked all fuses and trips and all ok. I called electrician. He said there is electricity getting through but only 115v not 240v. He has checked everything back to generator and would appear that there is no other problem. He is convinced that the problem stems from generator. The generator is 2.5kv Has anyone got any ideas?? Thanks
  • 3,799 Answers
Check the Power output switch is set to 240v. Yours may not have one because you haven't said what make and model of computer the motherboard is in. Incidentally computers don't generally have generators.
Posted on Nov 03, 2012
  • 18 Answers
SOURCE: ElitegroupP4M800pro, chrashes
you need to check your RAM settings or replace the RAM Good luck
Posted on Jun 04, 2007
jell587
  • 447 Answers
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Posted on Mar 06, 2009
  • 202 Answers
SOURCE: Abit V17 motherboard no monitor output??????
try vsing another video card, or check in the bios if it will post and see if the onboard video is disabled. if it won't post you either have a bad or mismatched(processor to motherboard) motherboard, processor or video card.
Posted on Jul 17, 2009
nonontech
  • 4737 Answers
SOURCE: No Display output from Motherboard
To troubleshoot the display, you need to disassemble the system, means you have to open up the cabinet and check the components and connections inside the box. I hope you will be able to open up the box so that you will get the view of the inner portion.
First, you need to disconnect or uninstall everything from the motherboard except the Processor with HeatSink Fan and the Power Connector(s). Unplug the Front Panel connectors (the connectors which come out from the front part of the cabinet, connected to the motherboard). You need to be careful with the main Panel, i.e. the power switch, reset switch, hddled, power led. Before you unplug them, note down the connection sequence if you might forget it. Also take note of the power switch pins, you'll need to short it after a while. Unplug the HDD data and power cables, Cd/Dvd Drive's cables, and everything else. Remove the ram, remove the bios battery.
(don't remove/disconnect the system speaker)
Now, connect the power cord and the monitor on the back, power on the monitor (I would recommend you to connect the monitor via VGA), take a screw driver and short the power switch pin on the motherboard (I've mentioned this to you to take note). Look at the cpu fan and on the monitor, at least the system speaker should beep this time with the beep codes indicating that there's no Ram/Memory installed. (If nothing happens, then there's problem with the motherboard, could be the video card or could be the bios or something else) If so, then turn off and install one Ram. Again power up and check the status, if there's nothing wrong with the Ram, Motherboard, Bios or video Card, then you must see the Bios' System info screen (black screen with white texts after the Dell Logo flashes). If it doesn't seem anything happen, then try with the other/another ram. (If it fails, then there's problem on the motherboard, you better get another than repairing it.)
If it boots up with the Bios System info screen, then turn off and connect the front panel and other panels, like usb or audio etc.. Again power On the machine from the Power switch (this time On/Off switch), verify what happens. if it's ok, turn off and reconnect the hdd and the dvd drive and so on.... untill everything is reconnected and reinstalled or you'll stuck somewhere during the steps when the faulty component is installed.
Let me know the outcome, sorry, this is too long.....but I don't want you to get confused.
Please don't forget to mention the motherboard model and make with the system configuration, otherwise, it's not that easy to troubleshoot..
Till then good luck.
Posted on Nov 09, 2010
Where are the ballast located on this unit
On a commercial fridge like a Traulsen, hidden under a panel next to the tube in the door, in the space between the top of the fridge compartment and the outer case, on the top of a tall fridge behind the grill, or in the base on a small fridge by the compressor. I can't see the model number, but have had a few Traulsens. I am a caterer.
Mar 15, 2017 | Televison & Video
I have under the counter commercial dishwasher that will not operator when turn on. Model SR24C ML130021, SN: 85-1054266
If you have checked that is has power and still doesn't work, I would phone a local catering repair company. Only they will have the knowledge and spares.
I am a career caterer :>)
Apr 06, 2016 | Dishwashers
Burnt circuit board
Need to check the wireing for ashort
Apr 10, 2014 | Dometic Rooftop RV Air Conditioner
Hand grips install
Try a company that caters to tractor-trailers. A lot of truck drivers will add grab handles for various reasons and you should be able to get them in an assortment of sizes and over the counter.
Sep 17, 2013 | Dodge Cars & Trucks
Enter too many pattern try using my google accont to access but failed
download HTC desk top manager and update your fone then master reset the fone using the desk top manager it should take any patters from it and the fone will be as when you buy it from the store
Mar 30, 2013 | HTC Inspire 4G Smartphone
Hi i have RGE 400 lpg fridge freezer its 10 yrs old on my catering trailer and used daily. Its stopped cooling the fridge and freezer compartments but the pilot light is ok. the metal tubes at the rear of...
I suggest you to check the Vents. I had a similar issue where my 12v compressor car fridge freezer stopped working and I found that I had put the Fridge Cover the other way round which accidentally covered the vents
Nov 22, 2012 | Dometic RGE400 Top Freezer Refrigerator
MY KITCHEN AID SIDE BY SIDE FRIDGE IS NOT COOLING. tHE COMPRESSOR IS HOT AND APPEARS TO BE RUNNING. Please help. Frank
1.The fan motor at the compressor must be running to keep the compressor cool.2. If you hear a clicking sound at the compressor,that is a indication of a bad compressor start relay that must be replaced.
Nov 11, 2009 | KitchenAid (KSRD22FKST) Side by Side...
I have a fault code LF2 showing on my Inomak fridge model No CF2140/PTL. Can you inform me what this is reffering to and how to repair it. Regards M. Carter
The LF2 Fault Code on the Inomak 2 door under counter freezer Model CF2140/PTL indicates that the Evaporator Sensor is faulty and needs replacing. If it Shows LF1 that indicates the cabinet sensor
Replacement sensor costs £25 pounds with £12 carriage via courier
Replay Courtesy of Catering Equipment Services – S Hayes ;-)
Oct 20, 2009 | Refrigerators
Dometic fridge. cooling it while traveling
If the trailer have good shocks absorbers, is posible traver with the unit on 12volts conection.
Aug 11, 2009 | Refrigerators
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Computers & Internet Logo
David Payne
David Payne
