Question about Epson Office Equipment & Supplies
Workforce 545 error a40
When i try to send fax , i keep getting an error a40
5 Suggested Answers
  • 24 Answers
SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Posted on Sep 25, 2007
Ajkill
  • 2035 Answers
SOURCE: Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Posted on Mar 11, 2008
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
  • 4 Answers
SOURCE: Epson workforce 610 cannot receive faxes
check your rx setting (receive) mode ?, fix it to auto mode
Posted on Jan 28, 2010
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
Leaving a space when printing
there is always 3mm margin in all sides of paper. Its Normal & you can not remove them.
If there is more than 3 mm than you should use nuzzle check.
Mar 28, 2015 | Epson Workforce 545 Wireless All In One...
Communication Error with Epson 545 workforce all in one printer
Go To Below official Epson Printer Page For Your problem, Communication Error
Still having Problem Then follow Us For Epson Printer Support
Feb 21, 2014 | Epson WorkForce 545 Wireless All-In-One...
Workforce 545 's ink pad is at the end of service life
As this remains unanswered but still picking up hits the Workforce 545 is basically the same design as the Epson BX525WD which is supported by a Printer Potty SoloLX kit for which installation is covered in this link
Instructions for installing waste kit on BX535WS
The error itself won't be resolved unless you find suitable reset utility such as the WICReset utility although this is a pay-per-reset solution. You can get both waste kit and reset bundled up if you want or you can go DIY to figure your own fix...
Nov 05, 2013 | Epson WorkForce 545 Wireless All-In-One...
Printer will not feed paper
Print paper has to make a 180 degree turn in thr printe- is this thick, stiff paper
Jan 05, 2013 | Epson WorkForce 545 - Multifunction fax /...
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
My epson fax machine is hooked to magic jack and every time I try to send a fax, I get: communication error 0404
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
