Question about RCA RCR450 Remote Control
Hello, I believe I have a remote similar to the RCR450. On the 450 some keys are blue, on mine all the keys are white, however, the set up is the same. I'm in need of a code for a Sanyo television I brought for my daughter for college. We changed the batteries but the code wasn't saved. Can you help us???????????
  • 231 Answers
Download the manual for RCR450 and look at the back pages =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Good Luck!!
Posted on Jan 04, 2009
Wiring on pioneer car stereo
Red is ignition....yellow is battery or memory....black is ground....blue or blue w/white stripe is power ant or remote for amp...orange is illumination (may not need)...white/white with stripe is front left i believe...grey/grey w/stripoe is front right...purples and greens are rear
Jun 18, 2016 | Pioneer Car Audio & Video
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
Some of my alphanumeric keys have both white characters and blue characters. I have accidently changed the settings such that I can no longer type the white key characters, only the blue ones. How do I...
you should have a button on your keyboard called Numlock or Key-lock or something similar. look for one that is colored blue, or has a blue light near it.
May 02, 2011 | Computers & Internet
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
Sep 03, 2010 | 2000 Subaru Forester
REMOTE OPERATES PLAYER BUT NO PICTURE....DO I HAVE IT HOOKED UP RIGHT ???
DVD players generally have 4 possible ways to connect them to a TV set.
1. Composite Base-band Video or RCA's (Yellow, Red, White)
2. S-Video or Super Video (S-Video, Red, White)
3. Component Video or YPbPr (Red, Green, Blue, Red, White)
4. HDMI or High Definition Multimedia Interface (HDMI)
If you are sure that the connections are correct at both ends make sure that the TV set is on the proper input for the DVD player's signal by pressing the input button, source button, or the proper input button as listed (some remotes have a separate button for each input) on the TV remote.
Feb 26, 2010 | JVC Televison & Video
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Blue screen with red key in bottom left hand corner
The Tv's Child Lock has been activated...
Hold down the F button and press the MUTE button to unlock.
You can only remove the child lock using the remote.
Mar 17, 2008 | Apex Digital PF2025 20" TV
Wiring diagram
Here's a link for a similar model. The wiring should be the same: http://panasonic.com.au/content/library/files/F001428.zip Most aftermarket car audio built in the last 15 years use the same eia wiring codes. They are as follows: Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Geen Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Sep 03, 2007 | Panasonic CQ-RDP152 CD Player
RCA RCR450 Remote Control Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
