Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer model #GVW9959KQ1 and its flashing CA. I bought this from a second party so I don't have a manual. What does that code mean? Where can I get a manual for this washer? Thank you, Jeannie
  • 530 Answers
Either that or you have a bad u joint causeing an overcurrent situation. check at the board first. make sure that you use he detergent because the regualr soap leaves a nasty build up.
Posted on Jan 04, 2009
  • erica graber Jan 05, 2009
    CA error code means it's an overcurrent situation. check the machine and motor board there is a fuse on one of them usually is's on the motor board. If it's blown you need to replace the board. the board is behind the touch panel
Screen reading CA
Hello there
The CA code means that the average current draw at the motor winding has exceeded 5.55 amps for more than two seconds. This could mean a problem with the drive motor, the thermal protector, or the motor controller board. Overloading the washer can also cause this fault. Page 57 of the manual gives specific tests for the drive motor and wiring harness.
Mar 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I am getting a CA code on my Calypso Washer. I can't figure out what it means, and I cannot find the manual.
CA stands for Average Current trip meaning there is a 2 second average of current draw greater than 5.55 Amps at the motor windings.
it could mean problems with the thermal protection circuit, the drive motor, or the motor controller pcb (MCU). Overloading the unit can possibly cause this problem but it is a rare thing to have happen.
Aug 09, 2010 | Kenmore Washing Machines
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error on washing machine
sounds like you have a bad motor controller board. there is a fuse on this board it's directly behind the consol on the left side. check the fuse if it is bad you know that is what your problem is.
Jan 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is leaking
check the boot hasnt split in the door well
Nov 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Repair manual
Somebody stated in a consumer product review that he found a repair manual mounted inside the front panel of the machine. He also gives some details of repair work that he did to his washer, so you may want to read the review for yourself. Link below: --> http://www.dealtime.com/xPR-Whirlpool-GVW9959K~RD-380361477764
Aug 04, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
