My computer does not recognize my modem so I can send a fax.
I have a Motorola Surfboard SBV 5120 modem. I want to set up and use Microsoft's Windows Fax and Scan program in Windows 7. I have used a USB cable to connect my computer to the modem, and an ethernet cable to connect the computer to the Linksys Router. I came up with the following link to update the modem: http://broadband.motorola.com/consumers/products/SB5120/downloads/542709-001-install-utility-b.exe, but it did not work. Apparently the link is inactive and the product no longer supported. Any suggestions?
    New Friend:
  • 124 Answers
2 completely different technologies.
FAX uses phone line (analogue) and router is digital.
It's one or the other.
Plugging what is essentially a modem into another modem was never going to work.
Scan and email is much faster and easier.
Or FAX to FAX through phone line.
Posted on May 14, 2017
Paeroa
  • 457 Answers
SOURCE: Motorola 5120 Surfboard
Yes it can happen after a reinstall.. You will need to go into the computer ie take the back off. Pull the modem out and put it back in in another slot exact to the one you pulled it out of. Try it again it will no doubt read this time.. It can only be done this way if you try to manually install a moderm it will load the standard one NOT your Modem. Goodluck!
Posted on Sep 09, 2007
SOURCE: Need to hook up Belkin G wireless router to Motorola SB5120
I have a Motorola SB5100 Cable modem and i have a belkin N wireless ROuter..i have conncted the wire from modem to router and computer to router and it doesnt work??what do i have to do??
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
Posted on May 04, 2009
  • 33 Answers
SOURCE: Motorola SB 5120. Can I connect the USB cable to
Certainly not. You just have to choose between the two.
Posted on Sep 07, 2009
  • 33 Answers
SOURCE: internet won't recognize our motorola surfboard
You need to register your modem with your cable provider. They will need the MAC address which is on the side or Bottom of the unit.
Posted on Jan 13, 2010
Searching for password on bottom of motorola surfboard SBG900
try this link
https://www.cleancss.com/router-default/MOTOROLA/SBG900
Jan 15, 2018 | Arris Surfboard SBG900 Modem Cable Modem...
Hi I have the Motorola SBV 5120 cable modem and it is currently connected to my PC with Cat 5 cable and my internet works fine. I want to make a wireless connection to my laptop which is 802.11 a/b/g/n...
The SBV5120 is simply a device that converts your cable internet signal to a RJ45 computer output that connects to your single PC
It also has two RJ11 phone jacks if you use the modem as your home phone as well. It has no wireless function,
For you to have a wireless connection, you will need to purchase a Wifi Router. These can easily be got at any local computer store or a big box retailer like Best Buy, Staples, Computer City etc,
Most come as a 4 or 8 port wifi router, your choice will be the number of wired connections. In your case it looks like one.
Once you have your router, connect the Modem RJ45 to the WAN input on the router and your PC to one of the LAN ports on the router. In its default state, it should connect you to the internet as normal.
The router will have setup instructions which you can use after you connect the modem and PC.
Nov 05, 2017 | Arris SURFboard SB5120 Modem
I can't get ports open on my surfboard 5120 modem, the router is configured properly and it showed them open when I first set it up but they closed and now I can't get them to open again. Once after...
call 1-877-466-8646 this is motorola's tech support line. Thier agents are very very good and will either fix your issue or tell you exacxtly where to go to get it fixed. But if they need to walk you through the set up process t does cost 30 dollars, but they can tell you how to get the set up info for free if you dont wanna pay
Oct 09, 2010 | Arris SURFboard SB5120 Modem
Is the average life span of the motorola cabble modem 5120 7 years?
I just spoke to comcast and they suggested three years isn't unusual for this modem to start having issues.
Jun 17, 2010 | Arris SURFboard SB5120 Modem
Internet won't recognize our motorola surfboard 5120 USB cable modem
Jan 13, 2010 | Arris SURFboard SB5120 Modem
Sep 01, 2009 | Arris SURFboard SB5120 Modem
Motorola SB 5120. Can you run the USB cable to a
Certainly you cannot. You just have to choose what connection to use. USB or Ethernet port.
Getting stuck on last step of software install motorola sb5120
i dont know. pls solve it yourself darling. Dont give it up...............
Jan 11, 2009 | Arris SURFboard SB5120 Modem
Sep 05, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
