How to go from av to on air on tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
With the original working remote if no source or video button on the set.
Posted on Nov 01, 2012
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
Apr 30, 2014 | LG 19LS4R 19" MULTISYSTEM LCD TV...
Connecting an Antena to a JVC 20220 how do i set up the tv to find channels?
Unless you are lucky enough to be close to one of the remaining low-power analog stations, you will need additional hardware to watch over-the-air programming with the AV-20220. You will need a digital to analog converter box. Connect the antenna to the converter box and then connect either the antenna output or the composite output to the appropriate input on the TV. If you use the RF input, set the TV to channel 3 or 4 and set the converter box to the same one.
Then to set the TV up to scan for any NTSC (analog) stations, you need to access the menu. There is a menu button on the remote. (I'm not sure about the AV-20220. Some of the later models (AV-27350) have a menu button on the TV as well.) Press Menu several times until you see Initial Setup (Setup). Use the up and down arrows (Volume) to navigate to Auto-Tuner Setup. Then use left and right arrows to choose Air. Use the up/down arrows to navigate to Start. Then press either the left or right button to start the scan for channels. Wait for the scan to end.
I hope this helps.
Mar 07, 2014 | Radio Communications
I have a calypso flat panel TV every time i switch it off and turnedit back on it comeson in AV mode with out me switching it from TV to AV,then i have to always go to the menue and put it bact into TV...
If you have something plugged in the AV, try unplugging that, and then switching on off etc tests. If that works and solves the problem, then the TV is sensing whatever is in the AV input, and thinks you want to use that first.
I'm not at all sure you can change this, except by making sure the thing in the AV input is either totally turned off, or unplugging it. I hope I'm wrong about this part, and if so it'll be clearly stated in the user guide some place about how to disable this auto-selection.
I hope this helps find the cause of your problem.
Dec 17, 2013 | Televison & Video
I have a vizio tv and i have ilo dvd player that i cant seem to get started can u help
is your dvd connected to tv...(video / av jack in) red to red white to white and yellow to yellow...now place a dvd in player press play..using the remote switch you tv to video/av 1 or 2 (your tv is already on cable/air ch 3)..now you should be enjoying your feature presentation...
Jun 29, 2010 | Televison & Video
I can't get Xbox 360 to work. I hve old TV, using converter box
If there's an issue with the AV cords themselves, the xBox's ring will flash red in all four sections.
You might want to try clearing out any dust or debris in the plugs and plug-inputs with some compressed air.
That's all assuming the AV cords or the converter are the problem.
Dec 03, 2009 | Microsoft Video Game Consoles & Games
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
AV 1, AV 2, AV 3, but no TV
that's thing happening you tv epprom ic. replace back same # epprom . good luck!
Mar 21, 2009 | JVC AV-27D302 27" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
