Question about Husqvarna Garden
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
After disengaging the mower control lever the blades continue to rotate, until the speed control lever is moved to it's slowest position. At that point a "clunk" is heard and the blades disengage.
  • 430 Answers
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Posted on Nov 01, 2012
  • 1 more comment
  • bernadett910
    bernadett910 Nov 03, 2012
    I did this prior to posting the problem. All spring appear to be in good working order with no obvious binds. It may be the PTO cable, will check this next.....Thanks
  • Jeff Hagemann Nov 05, 2012
    If the PTO cable is stiff it will not let the PTO pivot bracket return properly, also there is a return spring from the PTO pivot bracket to a slot cut in the deck that will pull the PTO off when the cable tension is released.
    ONE other thing to check if you have not found the problem yet.. the blade brake arms are activated by the PTO pivot bracket also. They have little plastic rollers on pins that engage in notches cut in the bracket. If the plastic rollers are worn or the brake arm is bent it will inhibit the movement of the pivot bracket.
4 Suggested Answers
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
Posted on May 10, 2010
54" Husquavarna cut,, won't move,,pulley froze up and I replacedpulley and belt,,,still won't move,,, starts right up,, pto engages
be sure belt is routed the right way
and disengage lever isn't pulled if its a hydro trans
be sure belt is around pulley on engine
Jul 04, 2016 | Garden
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Low gear does not disengage
Push and pull the speed reducer a whole bunch of times, it is stuck.
Mar 24, 2014 | Husqvarna Viking 1
John deere lx277
make sure if its a hydro drive disengage lever isnt pulled
Oct 03, 2013 | Garden
Freewheel lever broken
For the wire to come all the way out lever on top of the trans must be broken. I've seen a few. Jack rear of mower up, remove rear right wheel and find remnants of lever. With pliers turn this all the way forward, mower will now go. But to fit new lever trans will have to be removed. Dont forget the axle key.
Nov 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
TURNING RIGHT ENGINE WANT TO CUT OUT
sounds like the operator presence control switch needs adjusting.
Under seat.
Apr 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
664 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
