Question about Sewing Machines
Tension setting for chiffon on L4D
Tension Elna overlocker for chiffon
SOURCE: User Guide for Contessa MO 103 Overlocker
Hi Nikita,
I also am after the manual for the Elna contessa mo-103 and was wondering if you might be able to scan and email it to me? Am going crazy trying to get it threaded and tensioned correctly!!
Thanks
Posted on Apr 12, 2010
RichSew
  • 194 Answers
SOURCE: overlocker stitching is loose at cut edge of
Either the lower knife is too far to the left or your looper tensions are too loose. Check the position of the knife first.
Posted on Apr 14, 2010
SOURCE: new 344 elna overlocker - can't thread lower
I have been dealing with the exact same problem for 2 hours and no answers!! I have just discovered that if you move the stitch width finger to R instead of N, your threader will work!! Hope this helps :)
Posted on Nov 30, 2010
Tally Girl
  • 1133 Answers
SOURCE: I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Posted on Jun 13, 2011
aviral_srms
  • 1216 Answers
SOURCE: I have an elna t34d overlocker. Yesterday it was
Let's try the 10 minute tuneup. (I have a strong suspicion this is a misthreading issue, but it won't hurt to go through the whole thing.)
Dig out your manual.
Remove all the thread from the machine, top and bobbin.
Remove the needle. (Damaged or dull needles do all sorts of strange things to machines.)
Remove the needle plate, and if your machine has a removable bobbin case, pull that out, too.
Remove all fragments of thread and fuzz with brush and vacuum (don't use compressed air or canned air or blow -- it pushes fuzz farther into the machine where you can't get to it.) Pay special attention to the area around the feed dogs and the sewing hook area.
Lubricate the machine according to the manual's instructions if the manual describes using oil. Use ONLY sewing machine oil, not 3-in-1 type oils (they harden and freeze the machine) nor WD-40 (it's a solvent not a lubricant.)
Moisten a fold of well-washed cotton sheeting (like a bandanna or a pillowcase hem) with rubbing alcohol or unflavored vodka. Raise the presser foot to open the upper tension. Floss between the tension disks with the moist cotton fabric. Set the upper tension to 4 if you've been messing with it -- that's a good starting point for most stitches, most fabrics. If you have to go beyond the range of 3 to 5 to get good straight stitching, then it's time for a visit to the repair shop, most likely.
Inspect the bobbin you've removed. Is it nicely wound, or does it look uneven or lumpy? If it's uneven or lumpy, strip off the thread. Inspect the bobbin for cracks, chips, rough spots, etc. and then rewind it properly, following the instructions in your manual, step by step. Use only good quality thread - see: http://sewing.about.com/library/weekly/a...
Inspect the sewing hook, bobbin case, hole in the needle plate and all along the thread path, top and bobbin. If you find burrs, they'll need to be polished out with crocus cloth. If you're a beginner, let a shop do it for you or read John Giordano's The Sewing Machine Book for instructions.
Check to see the bobbin fits in the bobbin case properly-- this may not be a problem if you're using the bobbins that came with your one and only machine, but once you've got a herd of sewing machines, it's easy to mix up bobbins from one machine to the next. (Why no, I've never done that? Why do you ask??? )
Put in a new needle, turned the correct way around. If the bobbin case is toward the front of the machine, the flat back of the needle goes to the back of the machine. Backwards needles skip stitches. Make sure the needle is fully up in the needle clamp before you tighten it.
Open the manual to the section on threading, and read each step aloud before you do it... even if you've threaded it 8 jillion times before. Make sure you 1) Raise the presser foot when threading to open the tension so the thread can enter (this is what I suspect you're doing wrong) 2) Raise the thread takeup lever completely (the arm that moves up and down and is threaded after the tension).
Thread the bobbin case according to the instructions in your manual.
Raise the bobbin thread.
Pull about 4" of thread tail from both top and bobbin thread under and behind the presser foot.
Each and every time you start a seam, you're going to follow the steps below.
1) Raise the presser foot.
2) Place the fabric under the needle at the beginning of the seam.
3) Use the handwheel (or pedal or needle down button on some machines) to lower the needle into the fabric at the beginning of the seam.
4) Drop the presser foot.
5) Take 2 or 3 stitches while holding the thread ends behind the presser foot.
6) Drop the thread ends and sew normally.
I know this seems like a lot of fuss and folderol. But if you get in the habit of giving your machine a light cleaning the first time you sit down at the machine each day (just brush and vacuum; oil if required) and you correctly thread the machine and follow the seam starting sequence, this will solve many, many common sewing machine frustrations.
If the machine persists in misbehaving, stop and do the full "10 minute tuneup" and try again. Always, always take all the thread off the machine -- bobbin out of bobbin case, spool off the spool pin.
99% of the time, even if you don't spot anything wrong, this will fix the machine when you rethread. There was something that you didn't spot that was wrong, and the machine let you know by pitching a hissy fit. Happens to all of us, and this is the fastest way around things that I know.
If the machine persists in having problems,
1) check the needle to make sure it's new, of the right needle system, placed fully up in the needle clamp and turned the right way.
2) try different thread -- poor quality thread can cause some really difficult to spot issues.
3) if it's still having fits, it's probably time for a pro to take a look at it.
Posted on Aug 04, 2011
NEED TENSION SETTINGS ON ELNA OVERLOCKER F4 PLEASE
The tension settings on an overlocker are meant to be changed depending on the stitch your are trying to make. For the basic overlock stitch, it is usually recommended to start with the tension dials set at the midway point. However, machines differ, so those may even need to be tweaked. The tension is correct when all the threads meet in the middle of the fabric. It helps to test your machine using the 4 colors of thread so you can better see what is happening with the threads and you will be able to adjust each as needed.
overlocker tension Google Search
Feb 20, 2018 | Elna Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
How do I get the correct tension on my Elna 792D 4 thread overlocker?
ALWAYS Raise the presser foot when threading the machine. Give each thread and extra little tug when threading the tension disks so it seats completely. The midway point on the tension disk is the standard factory setting when using the standard thread weight, however, with use, age, and thread weight that setting may change. So, the user can use the midway point as a starting point for the basic overlock stitch but will need to make adjustments to get the correct tension. When testing your tension, it works best to use the 4 thread colors so it is easier to identify which thread is misbehaving. When you become familiar with your machine and how the stitch looks, it is easier to identify which thread is which.
Solving Serger Dilemmas
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwjjhv6Uw4PSAhXJrVQKHQrmCtgQFghBMAY&url=https%3A%2F%2Fwww.bernina.com%2Fen-NZ%2FExperience-NZ%2FSewing%2FSerger-projects%2FUSA-nz%2FSewing-Embroidery-nz%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-nz.pdf&usg=AFQjCNEAPID5FKBVa_amKfVmrTKgadlmRw&cad=rja
Remember that the tension settings will also determine the stitch you are trying to create. A basic overlock will generally have the tension set around the midway point, however, when changing to a rolled edge or some other stitch, certain tensions will be increased or decreased in order to create that particular stitch.
Feb 09, 2017 | Elna Sewing Machines
What is the settings on the elna overlocker 614de
For basic overlock stitch, usually the tensions are all set at the midway point, although there is usually some tweaking for any particular machine.
Oct 22, 2016 | Elna Sewing Machines
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
Free manual for elna overlocker l4d
contact elna customer service or a elna dealer and see if they can help you with a manual
Nov 19, 2013 | Elna Sewing Machines
What should the tension settings be for Elna Club 4D overlocker
Hi Nikita86,
Do you perhaps still have a scanned copy of the Club 4D overlocker?
Jul 10, 2012 | Elna Sewing Machines
What is the standard elna lock f4 thread tension settings
five on all tension dials and stitch length between two and three for a normal 'marrowing' 4 thread overlock. at factory tension dials would all be set to five.
May 13, 2011 | Elna Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
