Question about Alpine CDA-9811 CD Player
How to set the aux for iphone on CDA9811
I ran the wire out the back of the unit and now I need to figure out how to set the unit to play my Ipod/Iphone through it.
    Problem Solver:
  • 3 Answers
You will need to set up your system to accept aux. default setting is 'aux off'. refer to system manual to setup system to accept 'aux on' on pages 23 & 24. please read carefully as instructions are confusing.
Posted on Apr 19, 2009
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
How can I hook up an auxiliary wire to play my IPhone on the JVC KD-AR5000
After looking up your unit's info, I found that the aux input is on the rear of the unit. Pull the unit from the dash, being careful not to disconnect any wires (sometimes the antenna adapter wire is too short and must be disconnected to work behind the unit. Just don't forget to reconnect it before putting the unit back in place). Plug one end of a 3.5mm aux cable into the aux input on the rear of the unit and feed the other end thru the hole where the unit sits in the dash and out the side of the center of the dash to either the driver or passenger footwell. Replace the head unit and GENTLY pull the rest of the slack out of the aux cable but not so hard that you disconnect it from the head unit. You can tuck any excess aux cable up under the side of the console where the plastic meets the carpet, & if you wanted to get really fancy, you could drill a slot in the storage area of the console big enough to fit the cable, but small enough so the end doesn't fall through so you could plug your phone in and hide it all in the console out of sight. Then just switch the source on the unit to aux and enjoy!
Jan 12, 2014 | JVC Arsenal KD-AR5000 CD Player
I was wondering how do I play music through my iPhone with this cd player. I have a direct cable but I'm not sure what to press to make it play through my cd player. Thank you.
Once you plug in your iphone and set it to play your song(s). Set your car player for AUX this will then pick up the device playing into the direct port. Hope this helps Fix ya up.
May 12, 2011 | Power Acoustik PTID7002NR Car DVD Player
I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Nov 25, 2009 | Kenwood KDC-MP435U CD Player
How do i get to the AUX function? i'd like to play my mp3 player thru it. Also, what is the hole/plug? in the back of the unit for?
you will need to turn unit off and press the function button for a few seconds this will take you to a settings menu here you can adj the clock, aux imput , sub and rear spk out put and dimmer and other options,the 3.5 jack at the rear is for the connectin of steering wheel controls .
Sep 03, 2009 | Pioneer DEH-P3800MP CD Player
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
Pionner cd-iu200v plays video from Iphone, no picture on avh4100
Check the initial settings menu (you will probably have to reset the system to get it to reappear) and set the aux 1 to IPOD. This will let the ipod video play via the aux 1 just like it is supposed to. This solution is buried in the manual but is really hard to pull together.
May 11, 2009 | Pioneer AVH-5700DVD DVD AV HEADUNIT...
Playing a iphone on a standard honda radio
you need to identify the AUX input (it should be in the rear of the unit). If it is a standard mini plug, then you can use your iphone. If it is a proprietary harness input then you will need to buy the appropriate hardware fron a honda dealer.
Mar 28, 2009 | Car Audio & Video
Trying to play Ipod through my Alpine cda-9811
you need to set up your system to accept aux. this means you will need to set the 'aux on', as the default setting is 'off'. use the manual and refer to page 23 & 24. please read the instructions carefully, as they are slightly confusing.
Mar 15, 2009 | Alpine CDA-9811 CD Player
Pioneer DEH-P780MP
turn your head unit off, hold the function button and the functions menu to toggle the aux issue will pop up. its like an "off" function setting
Jun 29, 2008 | Pioneer DEH-P780MP CD Player
Alpine CDA-9811 CD Player Logo
418 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
