Question about RCA F36669 36" TV
My universal remote can't be used to turn speakers back on my f36669 tv
When using remote in menu mode,go to audio mode then to speakers can't turn speakers on.
    Top Expert:
  • RCA Master
  • 14,553 Answers
Not a surprise as Universals even if they program will be missing key and needed features.
Posted on Nov 01, 2012
android1
  • 5 Answers
SOURCE: RCA TV is locked
Try the POWER ON button on the top of the TV?
Posted on Nov 21, 2007
SOURCE: Input button
I cant gey my playsrarion to work through my audio input. Please email me a answer on how to fix this problem. Thanks for your time
Posted on Aug 17, 2008
rsheehan
  • 69 Answers
SOURCE: RCA console TV need to change to video mode without remote
Your cable box has a program mode in
it .You may be able to program it to change
inputs on your tv Is it a comcast remote?
Posted on Jul 01, 2009
  • 909 Answers
SOURCE: can't get the tv set to video input mode
You may be able to press the channel down button, past channel 1 to the av inputs.
It works on some tvs, but not all.
Posted on Aug 27, 2009
  • 117 Answers
SOURCE: I have an RCA F36669 tv that doesn't stay on.
look to see if the wire is in tv. unplug there 28000 volts there and it hurt use a long handel sew drive to find out unplug tv
Posted on Jul 09, 2010
TEAC Axia TV Model: LCDV 2605 set up to use surround sound speakers. Wish to revert to TV's own built-in sound system speakers only. Do not have a manualas was gifted a second-hand TV. Help?
If you have the remote, simply go into the audio menu and check TV speakers. If you don't then you'll have to either purchase a duplicate remote or find a universal which will allow you to access the audio menu of the TV. I'm afraid there's no other way that I know of. Good luck. So, you have no sound at all on the TV as is, correct?
Jul 26, 2017 | Teac Audio Players & Recorders
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
Marrying an older RCA TV to an RCA universal remote control
download the instru manual for remote control. www.fitness.manualsonline.com or www. retrevo.com
and proceed according.
God bless you
Jul 01, 2012 | RCA Televison & Video
How do i turn on the caption with universal remote RCr311W to a sanyo tv moel#DS27820 ?
Here is the link to the User's Manual for that universal remote control:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RCR311W_DOC_OM.pdf
Unfortunately there is no dedicated button on that particular universal remote for operating the Closed Captioning feature on your TV.
You can try using the MENU button on that remote in order to access the AUDIO OPTIONS on your TV. Then see if you can activate the CLOSED CAPTIONING from there. See page 5 of the above manual for instructions on how to operate the MENU button on that remote.
Otherwise you will have to use the original factory remote control that came with the TV, or go out and buy a more expensive / advanced universal remote control with all the additional features and buttons that you require.
Good luck.
Joe.
Dec 09, 2011 | Sanyo Televison & Video
My son might have been playing with the buttons on the TV and now we have no volume. I went into the audio sub window on the TV and I am having no luck getting the volume back. I cannot find the owners...
Hello
Enter into its "Menu" and srf through, come to "Audio" window. There you can see Audio Adj, Other adj, surround, speakers. Check the speaker status. Hilight the option "Speakers" If it is turned OFF make it ON. OK.
Jul 02, 2011 | Quasar SP-3235 32" TV
The tv speakers i believe are turned off and i need to turn them back on. how do i do this?
You need to get into the "Audio" portion of the Setup menu and set speakers to "on" Use the TV's factory remote to do this if possible, many universals will not have "menu" command capability. If you need further help, post a reply/comment and I can help further.
Jun 01, 2011 | Akai Televison & Video
I have Magnavox television model number TP2770 C101 when I turn it on it goes to the start up menu and I do not have the remote. how do I get to the regular tv mode? Read more: I have Magnavox television...
There may be a way to get to the audio and video without a remote by first pressing the menu button on the front of the set (if there is one), but the easiest fix is to invest in a good universal remote which will allow you to open the full TV menu. From the start up menu the remote will, after matching the code, allow you to go deeper into the start up menu to the audio/video menu and on to the "regular TV mode".
Jul 28, 2017 | Philips Magnavox Learning Universal Remote
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
Dec 23, 2010 | Symphonic ST419E TV
Turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
Jan 29, 2008 | Philips Magnavox 27MS343S 27" TV
RCA F36669 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
