Question about Maytag Performa PAV2200
Maytag electric dryer won't start
Ok, I took off the top and i have the back of the timer, the chime box, and three little 1x1 black boxes, and another black box that looks like the chime. Am I in the wrong place, I don't see anything round except the timer?
  • 163 Answers
Hi!! remove the top base cover of the dryer not the timer portion..
Posted on Jan 04, 2009
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have a squeeky maytag dryer that seems to be getting louder. Is there a lubrication that I can apply to a part?
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have is in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you open the front of the dryer?
Unplug your dryer from the electrical first.
You would remove the electrical box from the top of the machine that holds the timer switch/start switch,etc. Be really careful that no wires come loose in the process.
Then remove the top of the machine, then the front will come off after you remove the screws holding it together.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Won't start or heat up
Check your breaker box for fuse box. sounds like you are only getting 1 leg of the 220VAC to the machine.
Sep 19, 2009 | Maytag SDE3606A Electric Dryer
Wont start
On the side of the heater box is a small black thermal fuse with 2 white wires going to it. If this is open the dryer will not run.Replace it.
Dec 06, 2008 | Maytag PYE2300AY Electric Dryer
My Maytag Performa electric dryer (model #PYE2300AZW) will not start. I went through the troubleshooting guide online, but did not help. Is there a built in fuse that can be checked?
thermostat common problem for this machine ( dryers in general) bad thermal fuse, a result of poor venting usually.. with a putty knife or a screw driver the main top can be "poped" open , theres a clip perhaps 3-4 inches in on either side just under main top and from panel assy, after releasing the clips the top can be flipped back to reveal the heater and fuse are. the thermal fuse is located on the right side of the heater box, and can be tested for continuity. no continuity means is blown and needs replacing. part number LA-1053( about 30 bucks). if the fuse checks out ok the n i would check the heater assy and then the thermostat also mounted right there. simple continuity check for all three, all three must have continuity.
Mar 24, 2008 | Dryers
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
MAYTAG PERFORMA ELECTRIC DRYER WONT START
Same thing as other owners above...Dryer is five years old and is in need of a good cleaning of lint build-up. Model no. PYET444AZW.
I put a large load of clothes, which probably should have been spun again, into the dryer. When I returned the clothes were still basically wet, and the light in the dryer would not come on, and nor would the dryer start.
Tested the circuit breaker. OK. Tested the outlet with a tester pen. OK.
So in searching the internet for a solution, I found and read this string. Found the fuse, called my local appliance parts store and bought a thermal fuse kit for CDN$48 (incl sales tax). Kit came with three fuses.
Just opening the top of the dryer was a chore for a complete novice. However, the entire top is hinged at the back -- so at the front of the machine, just gently poked a slot screwdriver in the gap ringing the sides near the top, twist screwdriver and lift. Big fuse is easily accessible at the top near the back of the drum. It's a round thing about the size of a quarter screwed into a metal frame with two crimped-on wires coming out the top. One screw to removed the frame. Then detached the crimped-on wires, and removed the fuse from the frame with two more screws. You will need a smaller size ratchet or nut-driver.
While you have it apart you might as well change the second nickel-size fuse, too, although it is more of a pain.
You have to remove the coiled elements, which are basically just big springs. They come out with one screw on the right and a little finesse. The second fuse sits on the right-hand side of the metal box surrounding the coiled element. The screw for the coil also held the frame for the fuse in place, but the frame will still be secured to the box with a couple of small tongues. So you will still need to kind of lift and pull up on the frame housing the fuse. It requires some patience and finesse. Remove the crimped-on wires, and change the fuse.
Of the two smaller replacement fuses that came with the kit, there was one marked for a gas dryer and another for electric. (The big fuse was good for both.)
Then start putting it all back together. Took me two hours in all. But now that I have done it once, it would hopefully take me only 30 mins. now.
Finally, my replacement instructions suggested cleaning out your machine and removing the lint and other burdens which probably overloaded the fuse in the first place. So I bought one of those specialized lint brushes to clean out the trap and the exhaust hose and vent.
Sep 25, 2007 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
