Question about Kenmore 72175 Air Conditioner
Window A/C needs cleaning - lost manual
Embarrassing as it is, this isn't actually a very technical question: I have a window A/C unit that won't run, probably because of debris stuck in the fan after the winter -- this has happened to me before, but I forget the instructions the repairman gave me to open it up to access the part that needs cleaning. It was stupidly simple, but obviously not simple enough to figure out by myself. I've lost the manual and don't want to damage the unit by fiddling with it when I don't know what I'm doing. I live on the 6th floor - no balcony - so I can't clean it from the outside, and because it's bolted in and the bolts painted over (was like that when I moved in), I don't think removing it is really an option. This is the unit: -- it's a Kenmore, if that helps at all. We have already cleaned the filter - just don't know how to access any other part of the inside of the unit. Thanks in advance! Jo
  • 105 Answers
Remove the front panel & see if the unit will slide out of it's sleeve. Usually it is the sleeve that is bolted in, & the unit itself will pull out from inside.
Posted on Jul 15, 2007
Power window motor sounds like it's running but window won't roll down.
it happen with me also actually the problem is the power window get jammed from the inner part..... you if you able to open it just open now clean it well then spray the lube into it and for a long time it work properly..... thankyou
Oct 22, 2012 | 2002 Buick Rendezvous
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
There technically isn't a drain pan in AC units. Some have a little hole in the back, some do not. If they do not, then the evaporator fan "slings" up the water accumulated from the condensation in the air, unto the coil to help cool the inside of the unit. If there is no hole, do not drill into the machine. You are likely to hit a sealed system component and damage the unit entirely.
Jul 29, 2012 | Frigidaire Heating & Cooling
Locks won't work and Windows won't go down brought
Check for a broken wire in the door jam. Other wise I think, You need to research this more, that the Left Front Power Window Switch is actually a door module. I would guess it has either lost power or gone bad.
May 26, 2012 | 1999 Jeep Grand Cherokee
We have found that our window air conditioner had water inbetween the windows. We had a heat advisories out for today so it was running for a while. It's in a upstairs window where it gets warmer then...
Quite often the window units need to be tilted slightly toward outside to allow drainage to run outside the window. Try pulling bottom inward slightly so rear is tilted downward at outside and see if that doesn't cure it. You should soon see dripping outside at back of unit where it should be. Make sure you check for small hole under back end and check that it is clean and open.
Jul 02, 2011 | Electrolux FRA102BT1 Air Conditioner
I have a 2004 Cadillac CTS and after changing my battery the driver side windows won't go down. the whole electrical on the driver doors isn't working. what do i need to do?
First check your fuses (Manual should have that location for the window fuses). Also do the other windows go down on the other side with the switch on the drivers door? And what else doesn't work ( Mirrors, Locks )?
Jun 18, 2011 | 2004 Cadillac CTS
Manual window isn't connected to the hand crank somehow. window won't roll up or down.
inside the door is a winder, pull off the face of the door and check if the glass is coonnected with the winder. The glass is connected to the winder with silicone.
May 29, 2011 | 1995 Toyota Camry
Forgot my password need a new password
If you are looking to log into your Windows account and have forgotten the password, my guide may be just what you're looking for: If you're looking for a less technical solution, try logging in as the administrator after booting your computer into safe mode.
NB: You can boot in to safe mode by holding F8 at startup
Mar 07, 2011 | Computers & Internet
Need to purchase a manual for a Technics sa-gx290 receiver do you know where I could find one
Hi - Welcome to FixYa.
You don't need to buy one as I can provide a link where you can download the manual free:
Click on the above linke and the manual will open in a new browser window. The actual manual is in a smaller window within the main page. At the top of this smaller window, there is a disk icon. Click on this icon to save the manual to your PC.
If the manual doesn't appear in the smaller window, you will also need to download Adobe Reader:
Why pay when you can get it free - legally!
Nov 19, 2010 | Televison & Video
Remove it from the window,just slide it out from the shell,make sure there are no retaining screws,remove the front from the unit,and set it on a table outside,use a water hose and spray all debris from inside the unit,just remember not to spray hard stream of water directly into the coils on the evaporator,or condenser,you may have to remove some debris by hand if it is to large for the water hose to remove,make sure drain holes are clear,and let drip dry for about 30 minutes,then tilt unit one way,or another to finish draining the water,coils can be cleaned gently,just make sure nothing is restricting the air flow threw them,and make sure the fan has no objects in it`s way,then place the unit back in the shell in the window and you are ready for another hot hot summer.
May 28, 2010 | LG Heat cool Window Air Conditioner
Kenmore 72175 Air Conditioner Logo
447 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
