Question about Lexmark Interpret S405 Wireless All-in-One InkJet Printer
Lexmark s405 wireless installation problem
New computer installation, Tried on two diff' computers. Windows 7. Install the driver from Lexmark webpage. Cannot install the printer although it founded by the computers. Tried also by manual driver installation. None. Please help, Thanks in advanced!
  • Nate Ben Nov 03, 2012
    I added a Screenshot of the error getting after re-installing. By the way this computer is not around the printer - so I cannot connect it by USB cable.
    http://postimage.org/image/of22l00mf/
I have a lexmark interpret s405 and trying to connect with my computer. what do i do ?
Plug it in and your computer should look automatically for a driver, dowlaod the driver then install uit.
Aug 03, 2014 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark s405 not aligned
Try to update your printer firmware. The update will help improve your printer's overall performance. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the error continue to display on your computer screen, please contact Lexmark Technical Support Center for additional assistance.
Mar 16, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I've lost the cd that came with my s405 printer
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 24, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Can't insall the lexmark to my computer to print from computer
Welcome to FixYa!
Please reply back with what operating system are you using, e.g. windows xp, windows vista or windows 7 and indicate if it is a 32bit or 64bit.
Printer installation issues are mostly associated with incompatible drivers.
I will be waiting for your reply.
Oct 14, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a Lexmark S405 that was installed on my network, since getting a new router the printer will now not connect to either my desktop or laptop, I have tried reinstalling software but neither computer...
Try to reset your printer's wireless network adapter. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Defaults. The WiFi light on your printer will momentarily turn off then on to a solid orange light. You may then run the printer wireless setup utility on your computer to configure the printer for wireless connection.
Sep 06, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have Lexmark Prestige 805 It seems like I keep losing my printer connection, I have to turn the power off the printer and back on again to make it work or re-download the print driver. I used to have...
Please follow the steps below to fix the problem you are experiencing:
First, uninstall your existing printer driver from your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark folder.
  4. Pro800 Series folder.
  5. Uninstall Lexmark Pro800 Series.
After the uninstall process, reboot your pc when prompted. When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type if it's a 32-bit or 64-bit.
Second, use the link below to download and install the Lexmark Prestige Pro805 driver for Windows 7 from the Lexmark website. Use the correct driver for your operating system.
- Lexmark Prestige Pro805 Printer Driver for Windows 7 32-bit
- Lexmark Prestige Pro805 Printer Driver for Windows 7 64-bit
Follow the instructions on your computer screen to re-install the printer driver.
Sep 01, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
I cant print wireless and how do I set up the scanner to work?
Your wireless communication problem could be caused by several factors. Try to check the status of the WiFi light on the printer. Here's How to identify a Wireless Communication Problem and Resolution Tips.
For your other concern, make sure the printer driver is installed on your computer. The Lexmark OCR scan software, used to scan documents for editing, is available only in the install disc that came with your printer.
For the step-by-step instructions on how to scan, please refer to the Lexmark S405 User's Guide.
Jul 26, 2011 | Lexmark Interpret S405 Wireless All-in-One...
It seems that the driver to print did not install. i can fax, copy and scan but not print. message - no compattable printer installed. i did download it from the web aswell. im having an hp620 notebook...
It could be a printer driver issue. Try to uninstall your existing Lexmark S405 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark > S400 Series > Uninstall. After the uninstall process, reboot pc when prompted.
When your pc turns on, go to Start menu > right-click on Computer > Properties. Take note of the System Type (32-bit or 64-bit).
Use the links below to reinstall the printer driver: - Lexmark S405 Driver for Windows 7 (32-bit) - Lexmark S405 Driver for Windows 7 (64-bit)
Jul 24, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do I connect my lexmark printer to my windows pc?
Go the the Lexmark website and download the correct install program (free) for your OS. Follow the directions exactly, specifically NOT plug and play. You will need access information to your router, in order for it to work wireless.
Jul 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have lost my lexmark interpret s 405 software. how can i download now
Hi john
No need for disc, don't worry.
lexmark interpret s 405 drivers (win 7/8) can be found at
driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Aug 09, 2010 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark Interpret S405 Wireless All-in-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
