Sharp XE-A301 Cash Register locked out will not respond?
LED Display Shows Not Assigned or REG in the right hand corner of display- what do I need to do to get working again?
4 Suggested Answers
  • 360 Answers
SOURCE: cash register sharp xe a203 is showing an H and it
the printer arm is didnt locked,
close printer arm correct
Posted on Jul 06, 2010
Yogger
  • 117 Answers
SOURCE: Hi I have a cash register
it depends which model of the scanner did you purchase. As there are several models available, see below:
MS3780-9 OCIA and RS232 Transmit/Receive MS3780-11 RS485 and Full RS232 MS3780-38 RS232 Low Speed USB*, Keyboard Emulation Mode or USB Serial Emulation Mode MS3780-40 Full Speed USB MS3780-41 RS232/Light Pen Emulation MS3780-47 Keyboard Wedge, Stand-Alone Keyboard and RS232 Transmit/Receive MS3780-48 Stand Alone Keyboard and RS232 Transmit/Receive MS3780-120 USB and RS232 Transmit/Receive with EAS
As I checked the Sharp cash register, there are 2 RS232 connectors. So you probably have the MS3780-38, MS3780-48 or MS3780-120 model of the scanner.
To connect the scanner with RS232 interface of the cash desk please use the cabel 53-54000-3. You would also need a power supply. Im not sure in which country do you want to use the installation, so please select the right model for region from the list below:
AC to DC Power Transformer - Regulated 5.2VDC @ 1A output. 46-00525 90VAC - 255VAC United States, Canada and Japan 46-00526 90VAC - 255VAC Continental European 46-00527 90VAC - 255VAC United Kingdom 46-00528 90VAC - 255VAC Australia 46-00529 90VAC - 255VAC China 46-00530 90VAC - 255VAC India
I hope it helps.
Posted on Dec 13, 2010
Daniel S
  • 4323 Answers
SOURCE: Sharp cash register er 3310. Can do Programming
Hi
This can either be due to a jammed paper roll or a failed transaction. Check the printer to make sure that the paper roll is full and installed correctly, a paper roll can easily jam the printer. Make sure that you are yousing a good quality paper. Refrain from touching the print head or the motor while installing paper. To by reset the "LOCk" condition press the "CL" key, then press "ESC" twice, this will bypass the transaction/error or other user input that has caused the machine to freeze up. Make sure memory is free on your register.
If you want to open the drawer manually then slide the lever located on the machine bottom toward the rear (The drawer will not open, if it is locked with a drawer lock key). Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 30, 2010
Hooking up a intellitrox tach on motorcycle but instructions only show for 4 6 8 cyls
Most Intellitrox Tachs will work on 1,2,4,6,8,10,and 12 cylinder engines. The mini-tach (MS9002) only works on 4,6 and 8 cylinders.
So if you have the mini-tach and do not have 4 or 6 or 8 cylinders, you should use a different tach. If you have a different unit, or have 4 cylinders, then see the second step below from their installation guide.
To change settings: (a light tap on the left button will engage the menu system: the right button will then be used to adjust each specific setting.) 1. Leftbuttonpressed:
Set # of digits in RPM display, using right button, display shows: (hundreds) 9900, (tens) 9990, and (ones) 9999.
2. Leftbuttonpressedagain:Set # of cylinders using right button, display shows: 01_C 02_C 04_C 06_C 08_C 10_C 12_C
3-A. Left button pressed again:
Set first digit on max RPM on gauge bar display (in thousands) using right button, display shows: 10__B to 99__B
3-B. Left button pressed again:
Set second digit max RPM on gauge bar display (in hundreds) using right button, display shows: 10__B to 99__B
4-A. Left button pressed again:Set RPM first digit shift light threshold (in thousands) using right button, display shows: 10_S to
90_S
4-B. Left button pressed again:Set RPM second digit shift light threshold (in hundreds) using right button, display shows: 19_S
to 99_S
5-A. Left button pressed again:Set first digit output switch RPM threshold (in thousands) using right button, display shows: 10_S
to 90_o
5-B. Left button pressed again:
Set second digit output switch RPN threshold (in hundreds) using right button, display shows: 19_S to 99_o
6. Left button pressed againWill return to normal mode, or if there is no new information to access, after 8 seconds, the
gauge automatically returns to normal mode.
When you have finished programming the settings, turn off the ignition to retain them in the gauge's memory. Next time you turn on the ignition, your new settings will be the default.
Nov 05, 2017 | Motorcycles
Why has cash register stopped working all of a sudden?
Amazon.com: Customer Reviews: Learning Resources ...
www.amazon.com/...Register/product.../B0006N8X3...
Amazon.com, Inc.Learning Resources Pretend & Play Teaching Cash Register ... However, it recentlystopped working and simply said 'DRAWER OPEN' no matter what we tried ...
Casio - Support
www.casio.com > Home > Support > FAQs
CasioFrequently Asked Questions - Cash Registers. ... How I fix my cash register if the Journal/Receipt is not printing? How do I load paper in my cash register?
Not Assigned Error Message On Sharp Cash Register ...
? 1:06
https://www.youtube.com/watch?v=cq1_zcY_DuQ
Jul 12, 2010 - Uploaded by shopstuffltd
Instructions on how to clear the 'Not Assigned' error message on the Sharp XE-A203, XE-A213 or XE-A303 ...
"Head Up Error" on a Sharp cash register - YouTube
? 2:53
https://www.youtube.com/watch?v=NXMbLjfjdro
Jan 15, 2013 - Uploaded by sharpelectronicsusa
Clearing the "Not Assigned" and "Head Up" Error on the XE-A40S, XE-A41S, XE-A42S, XE-A401, XE-A402 ...
Re: Cash register notification stopped working - The eBay ...
Dec 12, 2015 | Royal Alpha 1000ML Cash Register
Sharp XE*A20S error code 7-15P
It sounds like you are seeing the time display. Turn the key to REG mode and try pressing CL (clear). If it doesn't beep, get the keyboard checked by a technician
May 12, 2015 | Sharp XE-A202 Cash Register
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
I want to know how to not have two additional 00's in the right hand corner of my DS 700 calculator
You're seeing an exponent, the power of ten.
To have the calculator not display this (unless the number won't fit into the display otherwise), press MODE repeatedly until the screen shows "Fix Sci Norm". Press 3 to select Norm.
If you need a manual, you may download one here.
Feb 24, 2012 | Office Equipment & Supplies
NOT ASSIGNED CODE
NOT ASSIGNED means no cashier is signed on. Find the cashier number button, probably labeled CASH #. In REG mode, press CL to clear the error, then 1, then CASH #, and Cashier 1 will be assigned. The display will show -01- Go straight from here into your sale.
Some registers are set up to not show the cashier number on the display or receipt. If 1 CASH # doesn't work, try CASH #, 1, CASH #.
Most users don't track sales by cashiers, so they forget they even have the capability, and they forget how to use that CASH # key. If you press the CASH # button without entering a number, it will sign out the active cashier, and you'll get this NOT ASSIGNED error.
Jan 23, 2012 | Sharp XE-A402 Electronic Cash Register
Can`t reset error not assigned on my sharp xea-213 cash register
No one has logged on. log on a staff member using their PIN number, then the CLK# button.
If anyone needs more information, the sharp XE-A213 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A213_operating_programming_manual.html
Dec 10, 2011 | Computers & Internet
Hi I have a sharp cash register XE-A303 - it displays REG 0.00 on the screen and when you put a sale through it says NOT ASSIGNED can u help please ?
You haven't signed on to the machine. CL, 1, CLK#
If anyone needs more information, the Sharp XE-A303 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp12.php
Oct 12, 2011 | Casio Parts Cash Register PC Desktop
My sharb cash register XE-A40S got error( Not assigned) I press CL+1+Clk ) dos not work what I have to do?
That is strange. You may have had the clerk sign on codes changed by someone. Make sure you are using the CLK# button at the top of the keyboard next to DEPT SHIFT button. Make sure the key is turned to REG position. If 1 CLK# doesn't work, try 2 CLK# or 9 CLK# Most machines will print the clerk number on the display once you enter it correctly e.g "-01-"
If anyone needs more information, the Sharp XE-A40s cash register manual is here: http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A40S_operation_programming_manual.html
Mar 15, 2011 | Casio Parts Cash Register PC Desktop
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Computers & Internet Logo
David Payne
David Payne
