Question about DeLonghi Heating & Cooling
My heater just stop working, no power, no lights. I checked the fuse. Fuse is fine im sure
Is there anyone who encounter the same problem that i had with my heater. This heater has electronic with remote control
I have the TCH7090ER and last night everything went out except the red light... nothing else works. Have you figured anything out?
Posted on Feb 03, 2013
  • maxnorfolk
    maxnorfolk Mar 11, 2013
    The same thing has happened to me
machtcl1
  • 61 Answers
SOURCE: all pro 200t
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
Posted on Jan 10, 2009
SOURCE: bmw e46 heater blower not working
I have a bmw 3 series e46 2000, the heater does not blow out properly, it just trickles out no matter wot speed the fans r on, could this be the final stage resistor or the heater blower motor?
Posted on Sep 01, 2009
  • 1550 Answers
SOURCE: k 484A fan forced wall heater
  • There will be four deep hidden screws on the back.
  • Remove the screws and pull off the back.
  • The element connections are push on spade connectors.
  • See if one of your came off. Just push it back on its terminal and it should work.
Posted on Oct 14, 2008
SOURCE: Hi, Last night none of the Dimplex storage
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Posted on Jan 04, 2010
  • 77 Answers
SOURCE: Our heater has no power. It may well be a fuse
with the unit unplugged, and using an ohm meter check for continuity all the way to the heating elements. the cover comes off by removing 4 screws, 2 on each side. you are looking for bad connection/broken wiring. also check elements for resistance.
Posted on Jan 22, 2010
I have a 2004 durango. The power mirrors, power locks, interior lights and alarm control all stopped working. Can someone help??
1st im sure the alarm stopped working because the power locks dont work (feedback issue) next on some models water from rain or car washes gets down inisde doors and shorts out electric devices in door , with that many things out im sure your gonna find a fuse blown in your panel , but i'll further bet that new fuse will go again next rain as well .
Feb 10, 2015 | 2004 Dodge Durango
Heater, horn, power window, brake lights, windsheild wipers, door locks dont work, I was told it was a computer chip that went out but im not sure.
i would first check fuses and power supply to these items, check that all voltages are present at the fuse box, computers are reserved mostly for engine management processes, if a loss of power is evident at the fuse box you may need to replace a fuse-link wire located under the hood
Jan 27, 2010 | 2004 Dodge Stratus
2003 Kia Spectra. My heater just stopped working,
Your manual ,in the glove box,will tell where the fuse panel is,and witch fuse,if the fuse is not blown,the blower motor has went out.Find the blower motor,and bump it with your hand,it may,or may not make it stat running again,but if it starts back up,then the blower motor is bad for sure,testing the motor with a test light will tell for sure if it is getting voltage to it,and if it is,then it is bad,if not,the blower relay,or the fan control switch is bad,test them with a test light also.
Jan 07, 2010 | 2003 Kia Spectra
I have an electrical issue with my 2001 civic. Everything was working fine and the next time i got in these no longer worked: Dome light, door locks, AC compressor, hazards, intermitent wipers, and the E...
I'm not 100% sure but I'm almost positive MOST of those are on the same fuse. Check your fuses and make sure that they're all ok and if not, reply back with more information.
Sep 25, 2009 | 2001 Honda Civic
Cd player and clock not working in 53plate clio
most of the time there is another fuse that shares another function such as the clock light so you cant see it, it might be on but not light up to see it, go through all the fuses and check if anything else is not working ie interior light etc. if all fails check the bulb in clock then get a multi meter to check for a power supply to the clock. im sure another fuse some where
Aug 15, 2009 | 2004 Renault 181
Radio and clock dont work 2003 windstar
Recheck fuse 18 (15amp) in the central under dash fuse panel.This is the fuse that feeds all of the items you listed.Make sure it has power to it. If it does not have power to it then it maybe the accesory delay relay which it is the center top relay in that fuse box,this relay is fed by fuse 6 (30amp) in the battery junction box under the hood.
Jan 31, 2009 | 2000 Ford Windstar
2005 Chevy Tahoe Trailer Running Lights Out
Depending on what type of trailer you have, a blown lightbulb on one marker could kill them all (like the old Christmas light strings). Look at those, and make sure your ground is good.
Nov 26, 2008 | 2002 Saturn VUE
Heating & Cooling Logo
688 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
