I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
  • gazzzz42
    gazzzz42 Nov 01, 2012
    try a new battery,should do the job for you
Just plug in the charger for a second and that will reset the led
Posted on Feb 17, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Posted on Nov 03, 2012
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
Connect my bluetooth headphones to my cell phone?
Also press and hold one of the buttons on the headphone to put it in discovery mode. Search google for your type and brand manual to find which button.
I have a sennheiser mm100 and there it it is press and hold for 5 secs the skip forward button when it is on, or 5sec the powerbutton when it is off.
good luck trying...
Nov 22, 2014 | Blu Dash Music 4.0 D272a Unlocked GSM...
Flashing blue light
1. turn it off2. hold centre button until blinking blue and red3. briefly press volume down4. turn it off= fixed :)
From Sennheiser UK:http://www.sennheiser.co.uk/uk/home_en.nsf/root/contact_menu_technical-question_telephone_headsets_faqs_mm400_series_bluelight
Jun 19, 2012 | Sennheiser MM 550 Wireless Headphones
I have bluetooth headset MM100 but Windows 7 cannot locate drivers for it.
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
Aug 03, 2011 | Sennheiser Sennhesier MM 100 Bluetooth...
Sennheiser MM100 bluetooth not working
Yes I had the same problem. Under some circumstances the MM100 freezes (didn't figure out when just yet). It's a software issue inside. Solution: open left speaker (the side with the charge connector and hence the battery). Discharge the battery (or just short circuit for half a second) and it works again. Sennheiser should built a reset button on these things.
Mar 20, 2010 | Sennheiser Radio Communications
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they...
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Nov 19, 2008 | Audio Players & Recorders
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
  • Blinking Red
  • Blinking Red
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
257 people viewed this question
 Grubhead
Grubhead
