Question about Dryers
Access to replace door switch
I need to replace the door switch for an electric
Kenmore dryer, Model C1108824080.
Thanks!
Nathan
  • Dryers Master
  • 8,205 Answers
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out so you can replace the door switch and actuator assembly:
Posted on Jan 04, 2009
Stopped working. Circuit breakers are not tripped, electrical plug in all the way
Hi and welcome to FixYa, I am Kelly. After this post I will need your dryers' complete model number For now check the door switch. As you just open or just close the dryer door, listen for an audible "Click" as in a micro-switch clicking sound. No click = door switch problem
Also open the door and turn the dryer drum by hand. It should also be turning the motor as you rotte the drum in both directions. I you can not feel the motor rotating or... it rotates in one direction but not the other there is a belt problem. The drum should not easily turn 360 degrees.
Check the door switch and check the belt. If after this is is still dead... there is more that can be done but, I need a complete model number for further comment. The model number will be 3 digits followed by 8 digits 110.++++++++
Thanks for choosing FixYa,
Kelly
Dec 15, 2010 | Kenmore 60172 Electric Commercial Dryer
My kenmore dryer 80 series electric wont turn on
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a video to walk you thru the repair. If you will post the model number of your machine, I will be able to point you the part you need.
Dec 08, 2010 | Kenmore Dryers
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
I have an electric Kenmore dryer that wont turn on
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Apr 16, 2010 | Kenmore Dryers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Dryer
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Eric
Jun 08, 2009 | Kenmore 64902 Electric Dryer
The door handle on the dryer broke,
yes you will need to open the door and remove the screws around the inside of the door and then the outer skin will pull off and you can access the door handle screws
Jan 31, 2009 | Kenmore 82822 Electric Dryer
Electric dryer not spinning
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Dec 04, 2008 | Dryers
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
162 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
