Question about Toshiba Computers & Internet
Replace ac power socket in laptop - Toshiba Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
Hi if you specialize in repairing computer, you can repair this ac power port by yourself on the basis of the following instructions:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Nov 01, 2012
4 Suggested Answers
The Joat
  • 81 Answers
SOURCE: AC power socket breaks of V7010 laptop
Glad it worked out for you.
Posted on Jan 21, 2008
  • 85 Answers
SOURCE: ac in socket keeps switching laptop off
Hi
Either you have a dodgy notebook PSU or the DC socket has a dry joint which will either need to be soldered or replaced. Either way i would recommend getting this seen to before you short the motherboard out.
Unless you are 100% confident with a soldering iron i would not attempt this yourself and instead take to a specialist.
Thanks
Taz
Posted on Oct 24, 2009
Jack_Dawson
  • 287 Answers
SOURCE: Acer Asipre 5315 laptop wont charge or turn on via
Check ur Laptop Charger (replace it)!
tell me if it helps...! :)
Posted on Jan 02, 2010
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Mar 30, 2013 | Gateway NV5207u Notebook
No power when plugged into ac
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 17, 2013 | Computers & Internet
My Asus get no power
Jan 28, 2013 | ASUS A9RP Notebook
I have a dv6500 laptop and was working and now power will not come on at all.
1. Please remove the AC adpater from AC power socket.
Check the power adapter output with Digital multimter. keep the multimeter in DC 20v range.
If the output is ok. then
2. Remove the laptop Battery from laptop and Remove the ac adapter from laptop
Press power on button for 10-15 seconds.
then connect the ac adapter to laptop and plug it to AC POWER wWITHOUT BATTERY.
Try to turn on laptop.
If laptop powered on .. shutdown properly and keep the battery and charge to full...
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | HP Pavilion DV6500T Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Studio 1537 touch power button wont work
1. remove battery and ac adapter 2. connect the ac adapter to a different power socket without connecting to laptop. just check if the power led on the ac adapter will lit on. 3. if ac adapter led is on, connect ac adapter alone without the battery then try to power on the laptop. check if the power button or the media controls lit on if not then replace motherboard.
Apr 20, 2010 | Dell Studio 1537 Laptop
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Bad AC connection, how do I fix it myself? soder the connection?
The AC connection is at the mains wall socket. I presume you mean the DC plug that plugs into the laptop or the DC socket on the laptop.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 28, 2009 | Dell Inspiron 6000 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
My Sony PCG-K10 Laptop is not powering up.
Either the ac adapter is defective or the dc connector on the motherboard is bad. I would test the ac adapter with a volt meter and make sure you are getting voltage through first. If there is power then likely the dc jack and someone will have to solder in a new connector
Jul 11, 2009 | Sony Vaio VGN-SZ660N/C Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
